Maintenance Schedule for a 2001 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-04-2009, 06:42 PM   #1 (permalink)
View Alexzander's Photo Gallery
I have a 2001 Camry 6 cylinder with 60K miles on it.
It occurred to me that I should have a maintenance plan for this nice car, as I plan on driving it until it dies...which will probably be a long time.
So I am asking you all if there is a maintenance schedule, of what should be replaced when over the miles, to keep my ride reliable. I am more than happy to spend up front so my wife and our baby are not stuck somewhere.
Any suggestions where I could find such information. Thanks to all, this forum is fantastic.
Alexzander is offline   Reply With Quote
Old 10-04-2009, 06:58 PM   #2 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
I know Toyota has the maintenance schedule somewhere on their site.
In general the oil should be ever 3-4k for conventional and 5-6k for synthetic.
Get a tranny flush about every 30k or do a drain and refill of the tranny every 15k (only changes half the fluid)
Coolant every few years, 30-50k miles.
Timing belt job at about 90k miles (important, or you WILL get stranded somewhere at any point after that 90k)
Brakes and suspension parts should be replaced as they wear out.
Tune up (plugs, wires, etc) every 60k
And lastly have fun driving one of the most over engineered, most reliable cars on the road.
carsrus is offline   Reply With Quote
Old 10-04-2009, 07:58 PM   #3 (permalink)
D.I.Y.'er since 2004
DxElite's Avatar
Gameroom cash: $259191
View DxElite's Photo Gallery
Get a Hanes Repair Manual for the car, if you have some basic mechanic skills it'll save you a lot of money doing the maintenance stuff yourself.
I have a 2000 Camry with I4 automatic and this is some of the maintenance interval listed in the Hanes manual that I follow:
3,000 miles / 3 months - Engine oil and filter change
6,000 miles / 6 months - Rotate the tires
15,000 miles / 12 months - Replace the air filter
30,000 miles / 24 months - Replace the fuel filter, change the transmission fluid (I drain/refill once a year and every 2 years I take off the pan to clean and check the filter.)
90,000 miles - timing belt service
Other fluids, brakes, and suspension replace/maintain level as needed.
'00 Camry 5sfe DIY&Custom mods car : Cardomain
-Dual Bi-Xenon HID retrofit w/ custom halos - Custom LED tail light build - Custom black and clear corner lights
-Custom interchangeable Short Ram/Cold Air Intake -Whiteline RSB - Custom Rear Strut Bar
DxElite is offline   Reply With Quote
Old 10-04-2009, 08:54 PM   #4 (permalink)
Ok, I am probably being a bit stupid, but are there other things which I should think about replacing, in order to make sure the car is more reliable?
Things I am thinking of would be the radiator, the battery, shocks, the alternator, etc. I guess I am trying to get a good idea of how long such components can generally last, and then replace them some reasonable time before they give out (hopefully).
All these things will die eventually, so why not replace them before they give out? But of course, I don't want to replace something that has a lot of life left in it.
Old 10-04-2009, 09:38 PM   #5 (permalink)
The radiator isn't a maintenance item. Same with the alternator really. Struts should be replaced about 80k but there not going to hurt anything from a reliability standpoint.
Replacing the battery at the end of the warranty is alright i guess.
The timing belt and associated parts are really the only thing you have to worry about, everything else is a no biggie and wont really cripple the car completely if they give out.
Old 10-04-2009, 11:14 PM   #6 (permalink)
View AlmightyCamry777's Photo Gallery
Only 60K? Golly my 02 has twice that miles. Wanna trade? No, Dang.
The advice given by the other posters is sound, i have your car and engine and there is one important, but easy chore to attend to, ever 30,000 miles and no one may tell you you need to do it, so i will.
The inside of the throttle body needs to be cleaned, by hand, every so often. Due to engine design PCV gases go right inside it and over time it can cause mysterious engine problems like stalling and rough running, that you might wind up taking it to a shop for them for figure out for $300 and meanwhile all you might need to fix it is a can of cleaner for $4. There are several good diys on how to do it here is one.
How to: Cleaning Throttle Body, Pictorial
Some clever people also plumb in a cheap clear plastic fuel filter, from the auto parts that costs about $3.oo, into the pcv hose going to the throttle body. This will catch alot of filthy PCV gases and maybe double the interval you need to clean inside the TB.
AlmightyCamry777 is offline   Reply With Quote
Old 10-05-2009, 11:53 AM   #7 (permalink)
Well...
Let me ask this question in another way.
Does anyone have a schedule for the expected life of components that are not expected to last the life of the car?
Thanks for the tips on the timing belt, etc. They were useful. But just so I can plan my auto care, I think its a good idea I have an idea how long things last.
As for radiators and alternators not being a maintenance item, well I don't think its so clear cut. If the component has an expected life, and it will incapacitate the car if it breaks (and in both cases it would of course), then one should at least consider pre-emptive replacement.
As my wife is not an expert mechanic, if steam started rolling up from the hood, she would pull over and be stuck wherever that is. I am willing to spend a bit more to reduce such a probability. So...with that in mind, I consider all such items candidates for maintenance or pre-emptive replacement, whatever term you can accept.
Old 10-05-2009, 11:57 AM   #8 (permalink)
By the way, thanks Almighty...
The procedure for cleaning that component is very helpful. I completely forgot about that. I will try to do it this weekend.
