2000 Camry P0420 Code Novice
Hi, I originally posted this over at the other Camry forum but got no help or even any relies. Hoping someone here might be able to offer some assistance.
I recently bought a 2000 Camry, 2.2 L California emissions, 5 speed manual with 72,000 miles. Shortly after I bought the car, the CEL came on. I bought an Autoenginuity ST06 scanner, and pulled the codes showing problems with the S1B1 wideband AF sensor heater circuit. Bought a new Bosch wideband sensor and installed. Cleared the codes. Fine for a day and CEL comes on again. Shows code P0420 catalytic convertor.
In doing research, I realize there are a number of factors that can influence this code. So I scan and record while driving. B1S1 voltage shows a pretty classic waveform pattern within normal range. B1S2 (post cat) voltage fluctuates wildly to the inverse of B1S1. Essentially, when S1 spikes up, S2 voltage drops to 0 or near 0. Not the pattern I expected.
Maybe related and maybe not, when driving at a stable speed and RPM around 2000, engine timing advance would go into the red zone. Not during acceleration, but when cruising. I have no clue as to what causes this or how to correct.
I have an Excel chart showing the relationship of the S1 and S2 voltage changes over a period of time if anyone is interested.
Any suggestions?
Thanks!
