Which is the freakin STRUT? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-07-2009, 10:31 AM   #1 (permalink)
View numberforty1's Photo Gallery
Hi- 98 Camry CE 6 Cyl 3.0L
So I'm totally new to all suspension related issues, but I want to learn. I just had the front end aligned and the guy told me my struts and tires are shot (the struts from having +50K miles and the tires from absorbing all the shock that the struts were no longer absorbing). The tread on the tires is fine, but he said the belts inside were all beat up. Or something. Does that seem to make sense?
Anyway, looking at struts online I see all kinds of different things - just struts, strut assemblies, strut mounts - and I don't know which ones I need. Anyone have a link to what I should be looking for? Do new struts have new shocks inside of them? Are the struts only on the front end or the back as well?
I know, I'm clueless. But I'm a good do-it-yourselfer with other things so I thought its about time the ol' Hornet got the same treatment.
thanks for your help
numberforty1 is offline   Reply With Quote
Old 10-07-2009, 11:07 AM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
[QUOTE=numberforty1;2940730] The tread on the tires is fine, but he said the belts inside were all beat up. Or something. Does that seem to make sense?/QUOTE]
no, sounds like crap to me, only thing the shocks are going to do is cause uneven ware patterns on the tires.
here a diagram of the front
back
and the google search link where i found the images there seems to be a nice write up on how to do this job. also not lited there is a lower spring insulator
http://images.google.com/images?hl=e...=&aqi=&start=0
but shock struts bascialy the same thing just the coil sits around the strut while shocks have the coil or leaf spring to the side.
what your going to replace? just the strut, and what they labeled as the dust shield (we call it a berring common to go bad and make knocking noises) on the front, and just the strut in the back. maybe the strut boot (dust boot whatever) if they look dry rotted. some may say new spring sine those are 11 years old your choice.
^ and leaving it that way!
Old 10-07-2009, 12:07 PM   #3 (permalink)
ShawnM's Avatar
View ShawnM's Photo Gallery
When in doubt take it to another shop and get a second opinion.
--Shawn
03 Camry LE
97 Lincoln MarkVIII LSC
67 Mustang
ShawnM is offline   Reply With Quote
Old 10-07-2009, 12:19 PM   #4 (permalink)
'95 Camry V6 XLE
View eddie926's Photo Gallery
+1 for a second opinion from a REPUTABLE shop.
Also, do a simple test yourself. On each corner of the car, push down hard and let it go quick, i.e. trying to "bounce" that corner. If it feels firm and comes back up and stops quick, your struts are probably not shot. If if bounces several times as if though it's just sitting on a spring with no strut, then your struts might be shot.
Your struts shouldn't be shot after 50k miles though unless you've been off-roading, and the story about your tread being fine but your "belts inside being all beat up" sounds pretty suspicious.
Be wary if he tells you next that he needs to top off the Halogen fluid in your headlights
eddie926 is offline   Reply With Quote
Old 10-07-2009, 03:20 PM   #5 (permalink)
1994 5S-FYOU!
JCamry94's Avatar
View JCamry94's Photo Gallery
3rd Generation
You can go to a bumpy road, if you hear and FEEL "clunking" all over the place as if there is NO absorbancy of the shock to your car then the struts are probably blown. Locate which side(s) is doing it an replace.
+2 'When in doubt take it to another shop and get a second opinion."
ACCIDENT...
Help me bring 'er back to life!!!
BUY MY STUFF: http://www.toyotanation.com/forum/66...e-all-obo.html
Thanks
JCamry94 is offline   Reply With Quote
Old 10-07-2009, 04:49 PM   #6 (permalink)
View flyeri's Photo Gallery
It is not generally good practice to replace one side or just one strut unless they are relatively new and one becomes damaged or is defective. Just fronts or rears is ok but if they are all shot you should change the all together.
flyeri is offline   Reply With Quote
Old 10-07-2009, 05:03 PM   #7 (permalink)
1994 5S-FYOU!
JCamry94's Avatar
3rd Generation
Sorry meant front or rear instead of "side."
ACCIDENT...
Thanks
Old 10-07-2009, 05:24 PM   #8 (permalink)
whip_cracker's Avatar
View whip_cracker's Photo Gallery
Struts and shocks - pretty much the same thing. Camrys use the "MacPherson" style suspension, being that the strut houses the spring as well.
I'm getting all 4 corners replaced within the next week or so... purely coz mine are 14 years old and need replacing LOL! Should make one hell of a difference.
whip_cracker is offline   Reply With Quote
Old 10-07-2009, 08:13 PM   #9 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Take a look at this:
http://www.monroe.com/support/tec_struts.asp
The easiest way may be to use something like the Quick Strut:
http://www.monroe.com/products/quickstrut.asp
However, you may only need the strut and maybe the strut mounts, which often go bad in that generation and cause clunking noises.
I personally prefer the Gabriel Ultra strut at Autozone for typical driving (buy 3 get 1 free offer).
Old 11-05-2009, 11:00 AM   #10 (permalink)
Thank everyone for the help. I have a much better idea now of what I am looking at. My garage quoted me $450 for parts alone to replace the front struts and strut mounts. Does that seem high? I know he wants to replace the spring coil and everything...I'm wondering how necessary it is to replace the spring since that seems to double the price. I'm looking at RockAuto and wondering...
Should I get this for $180 each? - http://www.rockauto.com/catalog/moreinfo.php?pk=1124767
Or just get this for only $80 each? - http://www.rockauto.com/catalog/moreinfo.php?pk=502184
And the bearing plate on the first item is the same thing as a strut mount, right?
Again thanks so much.
Old 11-05-2009, 04:44 PM   #11 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
How many miles do you have on the car? The springs in general dont wear out, but the strut mounts can go bad.
carsrus is offline   Reply With Quote
Old 11-05-2009, 05:20 PM   #12 (permalink)
Gameroom cash: $303255
I am a fan of the Monroe Quick Sturts (the ones in the first link), since you are replacing everything including the springs and strut mounts and all the rubber pieces. That said, I have to ask the same question as carsrus, how many miles do you have on the car?
Mike
Old 11-06-2009, 08:13 AM   #13 (permalink)
She's got about 185K on her, but I don't know if the struts have been replaced once before or not. So should springs be replaced after 180K?
What do you guys think about this Gabriel Ultra strut from Autozone? Its only $63 and someone recommended it to me. If I just replace this part instead of the whole assembly I'll save $330!!
Old 11-06-2009, 09:35 AM   #14 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
i installed Gabriel on mine.. they were ok.. once i changed out the struts i compared the oem with Gabriel and didnt see much difference
Old 11-06-2009, 09:51 AM   #15 (permalink)
K...so anyone on whether to change the spring coil or not?
thanks
