Throttle body performance questions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-07-2009, 03:43 PM   #1 (permalink)
View Gamble's Photo Gallery
Will a v6 throttle body fit on a 4cyl? Are they the same size?
Anyone know the sizes>>?
Or has anyone gained anything from porting out the throttle body?
Gamble is offline   Reply With Quote
Old 10-07-2009, 05:06 PM   #2 (permalink)
1994 5S-FYOU!
JCamry94's Avatar
View JCamry94's Photo Gallery
3rd Generation
yes it sounds a little louder now
ACCIDENT...
Help me bring 'er back to life!!!
BUY MY STUFF: http://www.toyotanation.com/forum/66...e-all-obo.html
Thanks
JCamry94 is offline   Reply With Quote
Old 10-07-2009, 05:09 PM   #3 (permalink)
1994 5S-FYOU!
JCamry94's Avatar
3rd Generation
Acutally in all honestly I ported out my plenum and TB and I have a TB Spacer, it pretty much sharpened response at the higher end RPM's a bit and sounds very good IMO.
For smaller motors what I've seen is smaller diameter will = more low end and larger = more high end. However, will you see actual numbers? No, I doubt it.
ACCIDENT...
Thanks
Old 10-07-2009, 06:02 PM   #4 (permalink)
Momentum Car Crew Camry
View H.Rivera's Photo Gallery
question.. what TB Spacer are you using.. and on what engine..?
H.Rivera is offline   Reply With Quote
Old 10-07-2009, 06:30 PM   #5 (permalink)
1994 5S-FYOU!
JCamry94's Avatar
3rd Generation
It's made by Helix, on a 5S-FE.
ACCIDENT...
Thanks
Old 10-07-2009, 07:08 PM   #6 (permalink)
Mad Scientist
2wickedtoyz's Avatar
Gameroom cash: $248601
iTrader Score: 9 reviews
View 2wickedtoyz's Photo Gallery
the TB from a V6 will not fit on a 5sfe but you can have the mounting part from the 1mz welded on so you can use the TB from that engine. the TPS and AIC plugs in and doesn't have any issues. also the TB is a progressive type that will allow smooth response.
[url]http://www.cardomain.com/id/wickedtoyz[url]
Camry Wagon Crew
2wickedtoyz is offline   Reply With Quote
Old 03-17-2010, 10:57 AM   #7 (permalink)
Any performance gained by the tb spacer?
Old 03-17-2010, 03:28 PM   #8 (permalink)
1994 5S-FYOU!
JCamry94's Avatar
3rd Generation
Gains as always on the 5s-fe are generally negligible. It does feel a little more responsive, but the main reason I got it was to further increase the volume and depth of the sound of my intake setup
ACCIDENT...
Thanks
Old 03-17-2010, 03:39 PM   #9 (permalink)
Man these motors suck for gainning power. They are great for lasting a while. But it's hard to find anything for a decent price for no gains anyway. Intakes are over priced, so are headers. The underdrive pulley is a rarity if you can find one and it's still $200, nobody makes cams.
I guess I'm stuck with a slow car. Ugh I should just turbo it and call it a day.
Old 03-17-2010, 04:09 PM   #10 (permalink)
93 Camry LE 5S-FE
4Cyl'erThriller's Avatar
Gameroom cash: $428696
iTrader Score: 15 reviews
View 4Cyl'erThriller's Photo Gallery
Anybody know the theory behind how these things actually work. Is it just more air? It seems to me there is still no more air than can fit through the same diameter hole. I just dont want to throw away $100 but Im oddly intrigued. Thanks
4Cyl'erThriller is offline   Reply With Quote
Old 03-17-2010, 04:13 PM   #11 (permalink)
It could be tappered or change the velocity of the air flow. Lots of different ways to do it.
Old 03-17-2010, 04:18 PM   #12 (permalink)
View Marcluv's Photo Gallery
what do you refer low end torque or high end torque...my high end torque sucks...i would liketo increase that but i dont wanna lose my low end torque...what do you think
Marcluv is offline   Reply With Quote
Old 03-17-2010, 04:19 PM   #13 (permalink)
93 Camry LE 5S-FE
Im just curious. Ive seen claims as high as 22hp and 4 or 5 mpg gains. Now Im sure these gains are best case scenario. I would hope for half that on a good day. Im just wondering if its worth $100. JCam, You noticed any mpg gains?
Old 03-17-2010, 04:22 PM   #14 (permalink)
You won't get 10hp out of it no way. You can get maybe 3 maybe.
Old 03-17-2010, 04:25 PM   #15 (permalink)
93 Camry LE 5S-FE
Im not spending $100 for 3hp. Still want one tho. Just to say I got one maybe. Frankly Ive got better stuff to spend my $$$$ on at the moment.
