Vibration when heat turned on - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-09-2009, 02:18 PM   #1 (permalink)
Slowly learning....
View Retrospekt's Photo Gallery
Just started using the heat as it's getting quite cold in Chicago and I noticed something in my car.
I let the car warm up before even touching the dial. When the temp is almost at halfway I crank it to the second speed on the hottest settings. Almost immediately the car starts shaking. It's not in intense shake, but I can feel it in my butt and on the steering wheel. When I turn the heat off it persists for a minute or two, then stops. It'll do it continuously as long as I have the heat on.
Ideas?
Edit: My dog bone mount is worn, by the way. If that has anything to do with it.
1996 Toyota Camry | 4 Cyl. 2.2L | Black Paint with Tan Interior | All Stock | DEAD at 155k. Broken Crankshaft/Main Bearing
Retrospekt is offline   Reply With Quote
Old 10-09-2009, 03:14 PM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
um, is your coolant level good? last time since you changed your coolant? will it shake at half way? the heater coil maybe clogged.
^ and leaving it that way!
Old 10-09-2009, 03:21 PM   #3 (permalink)
Slowly learning....
Coolant level is good. Coolant was changed less than 1,000 miles ago with a Timing Belt change.
Old 10-09-2009, 04:01 PM   #4 (permalink)
Gameroom cash: $303255
Karl,
Just a hunch here. Is the A/C button engaged when you are turning on the heat? Did the A/C work in warm weather? I'm just guessing that if the A/C button is engaged it is turning on when the fan is turned on, and your idle up circuit to compensate for the extra load of the A/C may not be functioning properly.
Mike
Old 10-11-2009, 03:58 PM   #5 (permalink)
Slowly learning....
Nope, the AC button is not pushed in.
Old 10-11-2009, 10:50 PM   #6 (permalink)
96 3MZ M/T
chronoti's Avatar
i would look at the heater coil is clogged, remove the hoses going to the heater and hook a hose up to them and try to flush it out
