MAP Sensor, Code 31 (OBDI) 93 5SFE
Hi All,
I have a bit of a mystery on my hands. The other day, I was driving up a steep hill in San Francisco when all of the sudden my throttle cut out and I lost power. My CEL came on and I barely limped my car back to Sonoma County. I pulled a Code 31, the MAP sensor, so I went to picknpull to get another one but the code will not clear. I've tried pulling the EFI fuse and the negative battery cable, but the code still wont clear.
I read through previous posts and the symptoms seem to match a bad MAP.
--Bogs on sudden acceleration
--Burning a great deal of fuel, smelly exhaust.
--Knocking after attempting to punch the gas.
--No Power from the engine after 3000 rpm, engine just winds up.
--Starts when cold, then quickly dies
--Rough idle, almost like a miss
I've tried spraying the vacuum lines with brake cleaner, no change in idle. I thought it might be a fuel delivery problem, so I changed the fuel filter.
Any help would be greatly appreciated!
Thanks,
Marc
