Question about exhaust gasket - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-10-2009, 09:17 AM   #1 (permalink)
View FireFire's Photo Gallery
Hi All
MY 97 Camry le I4 need to replace the front exhaust gasket where the pipe connect to the mainfold.
Question one is do I need to replace the 3 bot? The toyota manual says that's not reusable bot.
Question two is do I need to apply some high temp silicon for better seal?
Thanks
FireFire is offline   Reply With Quote
Old 10-10-2009, 12:12 PM   #2 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
if the 3 bolts are in good shape, in term of good thread and not badly rusted, i would reuse them.
i don't think high temp silicon is good for exhaust pipe, it will melt and vanish in a few minutes probably.
the exhaust gasket are cheap, only a few bucks from local auto store or dealer. and any metal gasket like exhaust gasket are not recommended to be reuse.
http://mysite.verizon.net/vaio338168/avator.jpg
2002 2AZ-FE, LE Phantom Grey Pearl, Retrofitted with LS430 Projectors on SE Headlights. Aftermarket Foglight
bronzemaxell is offline   Reply With Quote
Old 10-10-2009, 12:42 PM   #3 (permalink)
Thank you very much.
Old 10-10-2009, 05:35 PM   #4 (permalink)
OKOK...
tough work.. the studs on the mainfold is really stupid design... Why don't they use bolts instead of screw? I have to replace two screw with stainless bolts from homedepot...
If anyone need to do that again, please get some 3/8 one and half inch stainless bolt.... I can't find any one and half bolt with full thread... I leave the about 1/4 inch on there because it's too big to fit the hole. You may try 5/16, they seems works.
