here is a tip to remove oxygen sensor, at least it worked for me,
i was trying to remove the oxygen sensor after the cat, and make a stupid mistake, i was trying to remove the sensor while the pipe was cold, pb blaster, liquid wrench, i even try impact wrench, and also 1/2" breaker bar with 3 ft extension, never work, ended round the sensor a little bit. then i google, and searched how to remove stubborn bolts, and found my solution
i didn't try to run car hot, afraid getting burn by exhaust pipe
so i went to walmart, bought a bottle of propane kit,
and heat up the exhaust where the oxygen sensor screw in for a good 5 minutes, not the oxygen sensor,
if you unplug the connector, you should able to use the 7/8" or 22mm close ended 6 point wrench. the oxygen electrical connector is just small enough to fit though the wrench.
after about 5 minutes of heating the nut area around the oxygen sensor, then i was able to break free the oxgen sensor while another hand holding the exhaust pipe for leverage. that was why i didn't run the car hot, otherwise, i wouldn't able to hold the exhaust pipe by hand, the exhaust pipe is designed to have flexes as well.
law of physics, heat expand, it breaks free the bond between the nut and the oxygen sensor,
