The later 6-cyl A540 series has a common fill (through the dipstick tube) but separate drains. Earlier 540 are like the 4-cyl -- separate differential fill/drain plugs. The A540 is not as bullet proof as the lower torque A140, but both are better than the newer Aisin U-series.
One good thing about HF torque wrenches is that they actually have a lifetime warranty. The Danaher-made Craftsman have really flimsy plastic lock ring that tends to break or the handle spins loose. After 1-year no warranty. But Danaher does make better ones for Lowe's and their own brand GearWrench with metal lock rings.
Black Friday sale may be coming this year (?) if anyone wants Craftsman ones at about ~$40. We'll see.
Originally Posted by chronoti
ha! just broke on of those tq wrenches. while your there get a set a hex head bits to pull the plug or your going to need a few allen wrenches. 10qt should be too much but you can always return extra, i think just a normal drain and fill should only be like 4 qt. but when you go under there it's very straight forward.
ummm what car are you working on? i know the 6 have a separate fill and drain for the differential (2 qt) not sure on the i4.
