Disable it. You probably have to disconnect the whole alarm module from the car in case it has immobilizer.
See if you can get a fax back for the RS alarm installation manual. Shows you all the wires and steps you need to install a Toyota OEM alarm by Fujitsu-ten.
From
http://www.toyotanation.com/forum/t96974.html
For anyone who needs the
fujitsu 10 faxback number here it is:
310-327-9905
you will need a
fax machine/number to recieve fax back from them.
Hopefully this information helps
Originally Posted by paul lang
car alarm goes off on my '99 Camry XLL when any door is opened. i can shut off the alarm each time by turning the key to Access and pushing the override/valet button on the lower left panel, below the dash. i'm looking for a permanent solution, either fixing or disabling the alarm.
i have no keyless entry; key only. i believe it's after-market alarm - the horn doesn't go off, and the valet button is present... purchased the car used.
