Dash LED sizes - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-17-2009, 10:43 PM   #1 (permalink)
'95 Camry LE coupe
View MurderedOut's Photo Gallery
Dash LED sizes
I would like to know the names of the LEDs I need for the circled bulbs. I want to do an all white LED dash and I'm not sure of the names or sizes I need to get from superbrightled.com.
and I'm not sure which ones I need to change on the back of the cluster.
And also the name of this light
Thanks.
MurderedOut is offline   Reply With Quote
Old 10-18-2009, 12:49 AM   #2 (permalink)
Don't get mad. Get even.
El Tano's Avatar
View El Tano's Photo Gallery
#74 or 194 (they are the same, just different number) for the dash and the air controls, as for the other little 2 for the a/c and defroster, I don't remember if they are 3mm, 4mm or 5 mm, measure the round base and you'll know...
What color do you want to go ?? I have a ton of those....
FYI, on the control knobs you will need to do some modification or the leds will be very bright in the center and no so bright on the sides....
Check here:
DIY replace bulbs for leds, a/c console etc gen4
I have no idea for the one on the sunroof....
Check this place out to:
http://autolumination.com/
another tip: make sure to study and measure all the bulbs from both sites, or you'll end up with tons of extra bulbs...
Good luck
El Tano is offline   Reply With Quote
Old 10-18-2009, 12:59 AM   #3 (permalink)
TOYODA KAMURI
the_professional's Avatar
View the_professional's Photo Gallery
On the instrument panel, you need to change the 4 #194s, & the one #74, the one with the blue socket, removable by a phillips screw driver.
Basically the one you find with a green 'condom' over it.
i love my 1992 Toyota Camry LE 2.2L 5S-FE - 73K
9005 NIGHT GUIDE LOW BEAMS|FOG LAMPS|PIONEER HU&AUDIO|KEYLESS ENTRY
1995 Acura Legend LS KA7 3.2L C32A - 87K
SADLY, SHE HAS MUCH MORE MODS...
the_professional is offline   Reply With Quote
Old 10-18-2009, 01:23 PM   #4 (permalink)
'95 Camry LE coupe
I want to go with white LED.
Thanks for the help!
Old 01-14-2010, 05:22 PM   #5 (permalink)
Lighting Specialist!
iovaykind's Avatar
Gameroom cash: $480582
iTrader Score: 8 reviews
View iovaykind's Photo Gallery
Sorry to bring this back from the dead, but murderedout, do you know if the two bulbs in the air control unit have the green condoms over them? I'd rather see white, than green, and might even tint them blue without switching them both to LEDs which have bad distribution.
iovaykind is offline   Reply With Quote
Old 01-14-2010, 07:25 PM   #6 (permalink)
'95 Camry LE coupe
They do have green condoms over them
