5sfe head bolts - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-18-2009, 06:06 PM   #1 (permalink)
Creeps228's Avatar
Gameroom cash: $286818
iTrader Score: 6 reviews
View Creeps228's Photo Gallery
5sfe head bolts
Does any one if the 5S head bolts are torqued to yield? Or if you can use the 3sgte head bolts instead of the OEM 5s ones?
99 5s w/ V6 '01 Solara Brake Conversion & 1985 AW11 MR2 5spd
Camry: Tokico Blue's w/ Ebiach Lowering Springs on Motegi FF7 17" Rims with FALKEN ALL SEASON SPORT TIRES
MR2: 7A-GE
FS: Gen 4.5 Clear lense/JVC HU&Radar
Creeps228 is online now   Reply With Quote
Old 10-18-2009, 07:05 PM   #2 (permalink)
Let The Awakening Begin
Red_T_SwiftCam's Avatar
View Red_T_SwiftCam's Photo Gallery
You can use oem 3sgte rod bolts, but the bolts will not clear the camshaft gears. So you will need to grind a bit off the 3sgte bolts, or you can just buy ARP 3s bolts they fit perfectly.
Red_T_SwiftCam is offline   Reply With Quote
Old 10-18-2009, 07:16 PM   #3 (permalink)
Creeps228's Avatar
so ARP 3sge head bolts will work perfectly?
MR2: 7A-GE
Old 10-18-2009, 07:46 PM   #4 (permalink)
Yup
Old 10-18-2009, 08:30 PM   #5 (permalink)
Creeps228's Avatar
well all i find is ARP 3sgte head bolts, and the 5s and 3s head bolts seem the same according to your statement
http://headbolts.com/toyota.html
MR2: 7A-GE
Old 10-18-2009, 09:48 PM   #6 (permalink)
The reason the 3s oem head bolts won't clear the camshafts gears is because they are a different style they are a bit taller than the 5s head bolts, so they cause an abstruction to the gears. I have all types of head bolts both 5s and 3s the arp ones for the 3s are just short enough to clear the gears.
Old 10-18-2009, 10:15 PM   #7 (permalink)
Creeps228's Avatar
where'd did you get them from?
MR2: 7A-GE
Old 10-19-2009, 10:39 AM   #8 (permalink)
I miss read this^ Its The ARP 3SGTE head bolt that work with the 5s head.
When i say 3s im talking about the turbo 3sgte engine, and not the NA 3sge beams engine.
Old 10-19-2009, 11:48 AM   #9 (permalink)
Creeps228's Avatar
ok so ARP 3SGTE head bolts would work fine then...
MR2: 7A-GE
Old 10-19-2009, 11:57 AM   #10 (permalink)
yesssssir
Old 10-19-2009, 12:12 PM   #11 (permalink)
Creeps228's Avatar
sweet, that really saved me alot of time looking up specs. Im glad. Thanks. Some can lock this now :]
MR2: 7A-GE
