Could be several things. Check the sway bar links for looseness at the ends. Also could be the rear lateral control arms; the rearward ones with the turn buckle in them. They have a ball joint on the outer end that can develop play. To check those, jack it up, grab the tire at the 3 and 9 o'clock positions and push/pull side-to-side to try to rock it. If it clunks at all, there's your problem. That's what mine had that was the source of some loud clunking.
How many miles on 'er?
