Rear Sway Bar - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-19-2009, 12:35 AM   #1 (permalink)
Chemist at Chevron
Gameroom cash: $314885
View bdy0003's Photo Gallery
Rear Sway Bar
With all the threads about suspension questions, I figure I ask some of my own. I have a 95 camry and would like to upgrade my stock rear sway bar. I looked at TRD, ebay, and whiteline, but they all had sway bars for gen 4s. ALSO, how do I know if my struts and shocks are still good? I tried the bounce test, and my car bounces back but it then goes side to side after that. FYI, I have 163k on my car and I dont think any of that has been replaced.
bdy0003 is online now   Reply With Quote
Old 10-19-2009, 01:15 AM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
struts need to be replaced, and the gen 4 bar fits the gen 3 and whiteline should have the gen 3 included?
^ and leaving it that way!
Old 10-19-2009, 01:30 AM   #3 (permalink)
Chemist at Chevron
The website says "MC-SX-VCV10 92-97" whatever that means.
Old 10-19-2009, 09:43 AM   #4 (permalink)
RU2CHKN?
RU2CHKN's Avatar
Gameroom cash: $191865
View RU2CHKN's Photo Gallery
yep the gen 4 camry and the gen 1 solara rear sway bars do fit the gen 3. In fact, I have the TRD rear sway bar on my gen 3 right now lol. Good luck trying to find one and if you do get one, you won't regret it.
RU2CHKN is offline   Reply With Quote
Old 10-19-2009, 10:02 AM   #5 (permalink)
'95 Camry 5S-FE
Gameroom cash: $267767
View 95PimpingCamry's Photo Gallery
You can get a TRD RSB from NVDIS1 on solaraguy.org. He works at a Toyota dealership and will give you a good price, roughly $150 with poly bushings.
Take note, if you buy a RSB that comes with gen 4 bushings (TRD) you will need the gen 4 mounting brackets. Don't worry they are only a few dollars.
All of the lag, none of the boost.
VTEC It's like waiting for really bad sex.
95PimpingCamry is offline   Reply With Quote
Old 10-19-2009, 10:09 AM   #6 (permalink)
RU2CHKN?
RU2CHKN's Avatar
^really? I just reused my gen 3 bracket and the bushings fit fine
Old 10-19-2009, 11:38 AM   #7 (permalink)
View 92Squiggy's Photo Gallery
Do they got Front and Rear TRD sway bars?
92Squiggy is offline   Reply With Quote
Old 10-19-2009, 12:00 PM   #8 (permalink)
TOYODA KAMURI
the_professional's Avatar
View the_professional's Photo Gallery
They do.
But, there is little effect with a front Sway Bar, mainly for cosmetic purposes.
The rear is what you want. I have a whiteline RSB on the rear, It pretty much fit right in.
i love my 1992 Toyota Camry LE 2.2L 5S-FE - 73K
9005 NIGHT GUIDE LOW BEAMS|FOG LAMPS|PIONEER HU&AUDIO|KEYLESS ENTRY
1995 Acura Legend LS KA7 3.2L C32A - 87K
SADLY, SHE HAS MUCH MORE MODS...
the_professional is offline   Reply With Quote
Old 10-19-2009, 01:43 PM   #9 (permalink)
'95 Camry 5S-FE
The gen 3 bracket is larger than the gen 4. The gen 3 may appear to fit, but you will notice that it applies almost no pressure, if any, on the bushing. The bracket is supposed to squeeze the poly bushing tight.
I know I've seen threads on here about this and a pic of both brackets together, along with personally comparing them when I got mine. Both brackets have the same bolt hole, same tab, same width, same depth, but different heights. The gen 3 is taller.
Old 10-19-2009, 01:45 PM   #10 (permalink)
Chemist at Chevron
I read on the forums that the guy on solaraguy.com doesn't have anymore. But in the meantime, whats the diameter of the TRD RSB? And whats the diameter of the stock. Whiteline has 18mm but I'm not sure if Toyota Camry MC-SX-VCV10 92-97 corresponds to my car or not. Also, on the page that lists my car, it says Camber adj bolt kit-17mm, and Camber adj bolt kit-15mm. Would I need to get these?
Old 10-19-2009, 05:43 PM   #11 (permalink)
RU2CHKN?
RU2CHKN's Avatar
oh ok gotcha and I have noticed that the gen 3 bracket is taller thx for clearing that up
Old 10-21-2009, 08:36 AM   #12 (permalink)
Chemist at Chevron
Whitelines are not adjustable? These are 18mm. What about TRDs?
http://cgi.ebay.com/ebaymotors/93-97...Q5fAccessories
Old 10-21-2009, 10:16 AM   #13 (permalink)
A stock Camry? Blasphemy!
Gibson99's Avatar
View Gibson99's Photo Gallery
yup i remember installing a trd rsb on drummer93's 93lxe 4cyl back in the camryman era - we had to fabricate a spacer to go between the body and the bushing. just happened to have some scrap metal that we could cut and bend and made a spacer for it. that way we didn't have to buy the new brackets. but that was it - the rest was plug n play. hardest part was feeding the stupid thing up through the exhaust and fuel tank straps. i think we ended up holding up the gas tank with a milk crate and some wood and then undoing the straps.
the trd rsb IS adjustable - 2 positions. in fact i'm probably going to adjust mine to the harder setting (furthest from the end of the bar) because i cannot get oversteer with this car - even when i brake in the middle of a turn. of course some people would say that a complete lack of oversteer is a good thing... but i'm not most people.
i don't think trd ever made a front sway bar for our cars, but whiteline does, or did. don't confuse the front strut tower brace that trd DID make for us. completely different purpose.
as for all the confusing chassis codes from whiteline... they are combining all the codes into one big mess:
SXV10 (gen3 4cyl)
VZV10 (92-93 gen3 w/ 3vzfe)
MCV10 (94-96 with 1mzfe)
The underpinnings of the gen3 (and gen4 for that matter) are virtually identical, so they can produce one bar for all of them. the 97 may be a typo, unless the australian gen3 bled into model year 1997. can anyone from down under provide info on the model year business?
98 Camry CE v6 5s
97 MX-5
95 Camry SE v6 2dr SC (sold)
www.gibson99.com
Gibson99 is offline   Reply With Quote
Old 10-21-2009, 07:08 PM   #14 (permalink)
RU2CHKN?
RU2CHKN's Avatar
TRD sway bars I believe are 19mm with both a track and street setting
Old 10-22-2009, 04:34 PM   #15 (permalink)
TOYODA KAMURI
Your Right!
My whiteline feels like a cross between the two settings in comparison to the TRD.
& also, yes the whiteline is not adjustable.
