Power steering pump problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-19-2009, 01:32 PM   #1 (permalink)
View camry314's Photo Gallery
I went out of town 2 weeks ago for a week and I came back, and there was no power steering fluid in my res. I was out of town last week for 4 days and I come back to an empty res again. The ground is wet, so I am thinking it is from the pump since its just behind and inside of the passenger wheel. Now what goes wrong with these things? could it be a loose line? When I start the car and a bit of fluid returns to the res, its foamy. Anyone have any ideas?
Originally Posted by Venom_5 View Post
"honey, i bought you this Recaro passenger seat to sit in my Camry - will you marry me?"
camry314 is offline   Reply With Quote
Old 10-19-2009, 03:32 PM   #2 (permalink)
340,000 miles+......
sk8ersublime's Avatar
View sk8ersublime's Photo Gallery
foamy prolly means that air is in the line or getting sucked in. I had my pump replaced 5 times in a matter of months....it was horrible. If you get it replaced, make sure you get Toyota OEM.
http://www.cardomain.com/ride/2915998
340,000+
sk8ersublime is offline   Reply With Quote
Old 10-19-2009, 07:49 PM   #3 (permalink)
Slowly learning....
View Retrospekt's Photo Gallery
Put a piece of cardboard under your car, get in the car, and start it. Then turn the wheel all the way left and all the way right for about a minute. Shut the car off and look at the cardboard. If it sprayed droplets, it's probably the power steering pressure hose.
1996 Toyota Camry | 4 Cyl. 2.2L | Black Paint with Tan Interior | All Stock | DEAD at 155k. Broken Crankshaft/Main Bearing
Retrospekt is offline   Reply With Quote
Old 10-19-2009, 09:00 PM   #4 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
if it's a steady drip, it could be the seal behind the pulley....doesn't happen often, but when it does, it'll have to be swapped out
HaHa
Old 10-19-2009, 09:09 PM   #5 (permalink)
Certifiably Insane
96paseo's Avatar
Gameroom cash: $160315
View 96paseo's Photo Gallery
Did the reservoir go empty while the vehicle was sitting or from normal use? Reffering to the bold text above, it sounds like it leaked out while the car was not being driven. If that's true, I would suspect a broken or cracked hose or a cracked reservoir. If it goes empty during normal driving, pump shaft seal and/or end seals on the rack are likely culprits.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door. New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
96paseo is offline   Reply With Quote
Old 10-20-2009, 06:34 PM   #6 (permalink)
Thank you everyone for the responses. It is a slow steady drip. I drips on the subframe, then onto the ground. I know its not the reservoir. I was thinking that it might be a leak from the connection between the hose and the pump housing.
96paseo, yes, it is draining from just sitting, not normal driving. Actually when driving, its fine. In a month, my car is going to have to sit for 3 months while I am on OCS for the Navy. I am worried that its just going to dump out and possibly cause issues.
I know that the foam means air in the system somewhere, but I am starting to get annoyed with it. I have to drive my Camry to Newport RI in a month, so it needs to be running well.
Old 10-21-2009, 04:18 PM   #7 (permalink)
Anyone have any other ideas?
