Was the problem with the differential spider? That's the weakest part because the small gear sizes. They usually break if a wheel spins and then suddenly gets traction. The load just shatters them.
Try
Jasper Engines, with 3
-year/100K mile warranty, like all good reman should:
http://www.jasperengines.com/transmissions.php
Check rockauto.com for
Marshall too.
If you're mechanically inclined and if all else are good, then swap out the differential unit. Call
Transtar:
http://www.transtar1.com/locations.asp
I highly recommend that you only go to a local
ATRA shop -- Automatic Transmission Rebuilders Association. Still get references if you can.
http://www.atra.com/source/members/m...rch/search.cfm
Originally Posted by felpz123
the front differential on my 94 went out and im wondering how much a new transmission would cost,and where to by one.
