Window screech in cold weather - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-19-2009, 11:13 PM   #1 (permalink)
View Camry LE 94's Photo Gallery
3rd Generation Window screech in cold weather
When my passenger side window gets about 3/4 the way up, it makes this god-awful screeching sound in colder weather that's almost as worse than nails on a chalkboard. I've recently replaced the regulator hoping that would solve the issue, however to no avail. The screech is still present! What could be causing this? Any help is highly appreciated.
1996 Toyota Camry DX [230K]
DEPO Chrome HL's w/ converted Nokya Arctic White 9005 low beams, CF Dash Kit, 14" AR Rims
Advanced Camry DIY'er Noob
Camry LE 94 is offline   Reply With Quote
Old 10-20-2009, 12:20 AM   #2 (permalink)
View msrdude's Photo Gallery
How cold is it? I doubt cold weather has to do with the screeching. Maybe rain got in and rusted it and is making the noise, or just like my car, it needs lubricant. Remove the door panel and add lubricant to the motor/window regulator. Might not be the problem, but that is what fixed my noise.
Cars that I own:
1996 Toyota Corolla DX
1996 Toyota Camry LE
2007 Toyota Camry SE
msrdude is offline   Reply With Quote
Old 10-20-2009, 07:24 AM   #3 (permalink)
well the noise only comes up when it's cold out... and what kind of lubricant should i use on a new motor?
Old 10-20-2009, 02:06 PM   #4 (permalink)
Just use any lubricant. Spray it on the outside. Maybe also check the weatherstripping around the door because cold air could be seeping in somewhere and causing the noise
Cars that I own:
Old 10-20-2009, 02:32 PM   #5 (permalink)
Gameroom cash: $124160
View CraigW's Photo Gallery
Make sure the front and rear tracks lower and upper are cleaned and the lower rubber track inserts are in place correctly and not folded or misformed.. I used simple green and some rags to clean mine out recently. Keep cleaning until the dirt stops appearing on rags. If you are going to lube use white lithium grease.
CraigW is offline   Reply With Quote
