5s-fe air intake hose clamps - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-20-2009, 07:55 PM   #1 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
dumb question. to make sure that air intake hose is tight I turn the clamping screw all the way in? i'm talking about air intake hose side connecting to the Throttle Body. there is a similar clamp screw on the other end of the hose connecting to the air filter box. hose seems tight, but those both screws still can be turned (around half way in).
sorry for such an idiotic question, but i just don't know
Old 10-20-2009, 10:32 PM   #2 (permalink)
Gameroom cash: $303255
Tighten the hose clamp screw (10MM hex) until the the hose can no move on the throttle body. Then tighten another half turn.
Mike
Old 10-20-2009, 11:13 PM   #3 (permalink)
抵抗は無駄です
fenixus's Avatar
thanks, but that's not easy to do, because the hose by itself sits so tight that it doesn't move even with no screw... needed to use both hands to get it off in first place ...
Old 10-21-2009, 08:49 AM   #4 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Mike's move means twisting, if it can wiggle or moves when you twist it, it is too loose.
I know that there are a couple of tabs that help with alignment, so you watch them to see if they move when you twist the rubber hose by hand.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 10-21-2009, 09:24 AM   #5 (permalink)
抵抗は無駄です
fenixus's Avatar
ah i see! thanks!
