It should be a pretty standard install. The trickiest part for me was the positive wire. I put it through the drivers side wheel well, through a grommet that had some wires in it already. It would be easiest to remove the wheel then the cover in the well, but I did it with the wheel still on. Then feed the power wire under the trim on the drivers side and then behind the back seats.
For your RCA, just feed similarly under the glovebox and then under the trim on the passenger side.
Ground should be easy, just sand the metal very good to the bare frame.
1997 V6 auto 160,XXX
1993 I4 auto 133,XXX - Blown transmission; Sold
