Rear Suspension/Control arms - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-22-2009, 11:50 AM   #1 (permalink)
View GtariSSt's Photo Gallery
3rd Generation Rear Suspension/Control arms
I've got a 95 Camry sedan with a "rear steer" issue. Turns out I've got bad control arms in rear suspension allowing rear wheels to toe in and out at will. Makes for a very freaky ride, with the rear end wandering all over the road, lemme tell ya. It's getting worse with noticeable noise and wobble from passenger side. There are 4 of these arms, 2 in front of rear "axle" and two behind, all running along axle toward center of car. I have wobble on both sides so I need all 4, I'm thinking. Trouble is, the parts alone are close to $600 at autopartsplace.com. That may be more than this car is worth at 220k miles and rust showing up around wheel wells. I just had timing belt and water pump replaced before I found this out. Grrr. I will also need a set of tires to get me through the winter, so we're talking about $1000 into a car that may be worth less than that next spring.
Any words of wisdom? Cheaper idea on parts? Scrap it for a couple hundred and start over with something else? Looking for a little help here.
Thanks
GtariSSt is offline   Reply With Quote
Old 10-22-2009, 12:39 PM   #2 (permalink)
View asushi's Photo Gallery
There is no reason those parts should cost that much. Try:
http://www.rockauto.com/catalog/x,ca...parttype,10401
i'd fix this common issue sooner rather than later
asushi is offline   Reply With Quote
Old 10-22-2009, 01:40 PM   #3 (permalink)
Gameroom cash: $303255
Are you sure it's both arms on both sides that are bad? Usually it's the rear-most one on each side that goes bad. Toyota refers to them as "rear lateral control rods"; number 1 is the one closest to the front of the car and number 2 is the rear-most one. The rear-most one has the alignment adjustment. You will also need a 4 wheel alignment after replacing the rods.
I have found these are dealer only items. If you do find a cheaper aftermarket source for these, let us know here on this forum.
Mike
Old 10-22-2009, 02:01 PM   #4 (permalink)
Dude - you are the MAN! Assuming, of course, that you are a guy.
Anyway, I was looking at OEM parts at 2 other sites, like I said close to $600 bucks, which would double what I figure the car is worth. Rock Auto (good ol' cheeseheads) had aftermarket Beck Arnley parts for $280 and some change shipped. Thanks!
Mike Gerber - Rock had limited supply of the adjustable rears, but try other Beck Arnley distributors.
Old 10-22-2009, 04:27 PM   #5 (permalink)
post pics when you get em, i'd like to see how they are adjustable.
Old 10-22-2009, 07:32 PM   #6 (permalink)
There is a sleeve on the rear-most one on each side, like a tie rod end.
Mike
Old 10-23-2009, 10:08 AM   #7 (permalink)
Mike
exactly
Easy to see by poking your head underneath from behind wheel.
Old 10-23-2009, 03:43 PM   #8 (permalink)
Love Machine
plbill's Avatar
View plbill's Photo Gallery
Too bad you don't live in Quebec. I have a set of new control arm sleeping in my garage and I want to get rid of them.
Camry 1992 2.2 LE
plbill is offline   Reply With Quote
Old 10-28-2009, 03:44 PM   #9 (permalink)
Got the parts yesterday, will get them put on this weekend. Looking forward to this! Starting to shake my fillings loose.
