Yeah, even at 20mph the brake squeal caused by indicators is usually quiet. Especially when they have just started touching. Also when you hit the brakes the indicator should either pull slightly away from the rotor (no noise at braking) or dig in towards the rotor (makes a noise liable to cause nearby pedestrians to run for cover).
I'd look at the axle cotter pin. I've never seen one make that noise, but it's easy to check out. If you have steel wheels just pull the hubcap off, if you have alloys pull the center cap off and you should be able to see it.
If it's not loose, just lift the front end, take off the wheel, put the tranny in neutral and spin the rotor. If the noise isn't there look at the wheel, if you do hear it, track it down. If you can't turn the rotor by grabbing the studs and spinning, you can always use a screwdriver or prybar in between the studs for a little extra leverage.
'96 4cyl 5spd Camry
147k miles and running out of things to fix...
