clicking on one corner - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-22-2009, 06:28 PM   #1 (permalink)
View asushi's Photo Gallery
a kind of rapid clicking on driver side front corner developed in the last two days. is this a common sound for impending strut failure? my strut boot is gone already.
could it be the end links?
asushi is offline   Reply With Quote
Old 10-22-2009, 07:35 PM   #2 (permalink)
Gameroom cash: $303255
Are you hearing this noise when making right turns? If so, it's most likely the cv joint that is bad.
Mike
Old 10-22-2009, 07:36 PM   #3 (permalink)
right. forgot to mention - this is not like a cv click. it happens only when the corner rebounds from a bump.
Old 10-23-2009, 11:49 AM   #4 (permalink)
Are you talking about a clicking noise, or 1 clunk when rebounding or going over a bump? Also, waht year is the car?
Mike
Old 10-23-2009, 12:04 PM   #5 (permalink)
A stock Camry? Blasphemy!
Gibson99's Avatar
View Gibson99's Photo Gallery
it could be the upper strut mount itself - gen4 had a real problem with these when new, and even with the updated part it still does it some. but check to make sure none of the 4 nuts you can see from the top of the car w/ hood up are loose - any of those could make some major rattles as well. to check teh center one, bounce the car while looking at it - if you see it moving up and down seperately, its loose. it should pretty much follow the movement of the black metal of the upper strut mount.
98 Camry CE v6 5s
97 MX-5
95 Camry SE v6 2dr SC (sold)
www.gibson99.com
Gibson99 is offline   Reply With Quote
Old 10-23-2009, 12:17 PM   #6 (permalink)
"it could be the upper strut mount itself - gen4 had a real problem with these when new"
That's what I was thinking too, and why I posted my last question about the year of the car. It wasn't all the generation 4 models; only the 97-99 models that had problems with the upper strut mounts. The mount was changed beginning with model year 2000.
Mike
Old 10-23-2009, 12:23 PM   #7 (permalink)
unfortunately it's a 93 v6 LE. i did a bounce test this morning and the strut performed superbly. I'm think it's just noisy endlinks now.
Old 10-23-2009, 12:33 PM   #8 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
sway bar bushing?
