Its the window motor. If you have a power probe, it will make your life easy. It sure did with my window problem. (but the power probe is pretty expensive). To make sure its the motor, remove the door panel from the door, and find the wire that connects to the motor. Remove the clip and apply the power probe to the wire. If it moves, then its not the motor and the problem is the switch. If it does not move, then it is the motor. My problem was the master switch for crying out loud. But luckily, the switch inside was dirty and was making a bad connection and a little cleaning did the job.
Cars that I own:
1996 Toyota Corolla DX
1996 Toyota Camry LE
2007 Toyota Camry SE
