plz tell me how to remove scratch (pics) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-23-2009, 02:21 PM   #1 (permalink)
View smilecow's Photo Gallery
I got some scratch but no dent.
which method should I use? paint? rubbing compound? polish compound?
which method will work fine? thanks
smilecow is offline   Reply With Quote
Old 10-23-2009, 02:28 PM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
(ms)paint.
^ and leaving it that way!
Old 10-23-2009, 02:35 PM   #3 (permalink)
OEM+
eyezack87's Avatar
Gameroom cash: $207080
iTrader Score: 7 reviews
View eyezack87's Photo Gallery
So are you saying that is a ton of paint transfer as well as mild scratches? How deep are they? If you can catch it with a fingernail then it may be too deep to repair without compromising the clearcoat....
If its alright, then take some Meguiars ScratchX and use a bit of "passion" with a foam applicator. That should slowly remove the paint and even out the scratch so it blends in. If you need something stronger that is OTC, Meguiars Ultimate Compound will work too. Good luck!
1996 Beige Lexus ES300
2010 Blue Ribbon Metallic Camry LE
eyezack87 is offline   Reply With Quote
Old 10-23-2009, 04:40 PM   #4 (permalink)
View flyeri's Photo Gallery
yep, try polish or light compound first. It may clean it up to where any scratches won't be noticeable.
flyeri is offline   Reply With Quote
Old 10-23-2009, 04:47 PM   #5 (permalink)
'_'
Touge Star
'_''s Avatar
Gameroom cash: $421512
iTrader Score: 10 reviews
View '_''s Photo Gallery
If you can't buff it out, you'll probably have to get that painted. I had damage in that same area and had a shop repaint it. Came out close to $1200 because they had to paint match with the rest of the body.
山道だいすきです。
http://www.cardomain.com/ride/2538603
'_' is offline   Reply With Quote
Old 10-23-2009, 07:13 PM   #6 (permalink)
View asushi's Photo Gallery
try some claybar with quick detail
asushi is offline   Reply With Quote
Old 10-23-2009, 07:36 PM   #7 (permalink)
View liensalebuyer's Photo Gallery
It looks like tire scuff marks which might be removed by rubbing compound, but it may make
thr area hazey. Still better than what it is now.
liensalebuyer is offline   Reply With Quote
Old 10-23-2009, 10:03 PM   #8 (permalink)
Do not buy from
View Zviator's Photo Gallery
Sand down the area. Check your color code in the VIN plate. Drive by Pepboys and pick up a $5 touch up paint kit. If your car is beige then dont expect it to match, just live with it.
Zviator is offline   Reply With Quote
