Hello
I own a 99 camry. my headlights dont turn on. So I checked the manual and found out the problem was a wire harness. the wire is red with white line in a 2k connector of the fusible link block. I tried to find the wire harness but I couldn't. However, I could find that wire harness in my friend's 98 camry.
whoever has a 99 camry, plz check the that red wire is there. it just takes less than 5min and easy. you just need a flat driver. I have pics below
1. pull the block with a flat driver
2. find this white connector that is second row
3. check red with white harness is there.
