I changed this gasket last year but didnt post because this was too easy but somebody asked how below a thread so I posted.( my car is a 99 2.2l camry)
tool needed: 29mm wrench(or socket),10mm wrench(socket) nose plier, high temp rtv,
level: as easy as changing oil
1) detach the breather hose ( blue circle)
2) remove the 10mm bolt and move the harness aside(red circle); I did this
but not necessary.
3)remove the 4 BOOTS
with a plier (NEVER pull the wire)
[IMG]file:///C:/DOCUME%7E1/ADMINI%7E1/LOCALS%7E1/Temp/moz-screenshot.jpg[/IMG]
4) remove the 4 nuts with a 29mm wrench or socket( no need any lubricant. easy removal)
5) remove the cover with a flat driver.
you need to pull up
6) you should place some newpaper and a bucket for some drop of oil, not much.
7) remove the gasket by just pulling
8) remove some left seal with thinner( I didn't do that. You mostly are not going to do that)
new valve gasket and high temp rtv( I purchased boots but I didn't install. I recommend not buying boots except boot problems)
9) install the gasket
10) put the rtv on both side left and right
reassemble everything in reverse order.
When I did this, I got 135k on it with every 3k conventional oil change. It was more cleaner than I had expected.
I should keep changing oil 3k.
