HELP - cannot get the rear wheels off! what's wrong? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-25-2009, 01:07 PM   #1 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
i'm in the middle of the job. jacked up the rear of car and put it on stands. wheels are rotating freely, removed all 5 lug nuts.
still i cannot take the rear wheels off. what's wrong? please help!
Old 10-25-2009, 01:14 PM   #2 (permalink)
抵抗は無駄です
fenixus's Avatar
anybody please?
i think i'm going to the store for a sledge hammer ...
Old 10-25-2009, 01:17 PM   #3 (permalink)
rusty9's Avatar
Gameroom cash: $440405
View rusty9's Photo Gallery
yeah just give it a few good whacks with a large hammer.
rusty9 is offline   Reply With Quote
Old 10-25-2009, 01:18 PM   #4 (permalink)
'95 Camry 5S-FE
Gameroom cash: $267767
View 95PimpingCamry's Photo Gallery
I'm guessing that you have steel wheels?
If so, you probably have the wheels slightly rusted to the hubs. If your car is securely placed on jack stands, just kick the wheel at 12 o-clock, then 6 o-clock, then 3 o-clock, then 9 o-clock. If the wheels still won't come off, repeat until it will.
In the future, it will help if you put a little anti-seize on the hub.
I personally wouldn't use a sledge hammer for fear of denting/bending the wheel. Your foot should be a little more forgiving.
All of the lag, none of the boost.
VTEC It's like waiting for really bad sex.
95PimpingCamry is offline   Reply With Quote
Old 10-25-2009, 01:49 PM   #5 (permalink)
Gameroom cash: $303255
Correct, your wheels are rusted to the hub. Very common. As 95PimpingCamry has said, make sure your car is very secure on the jack stands. Then get under there with a hammer and a piece of 2 X 4. Place the 2 X 4 at various points on the inside of the wheel and hit the 2 X 4 with the hammer. The 2 X 4 will keep you from damaging the wheel or tire. It should break free with a few whacks.
Mike
Old 10-25-2009, 02:16 PM   #6 (permalink)
Slowly learning....
View Retrospekt's Photo Gallery
I just had my brother hold a large piece of wood on the wheel while I gave it a STRONG kick with my heel. Just make sure the car is secure on jack STANDS, not just a jack.
1996 Toyota Camry | 4 Cyl. 2.2L | Black Paint with Tan Interior | All Stock | DEAD at 155k. Broken Crankshaft/Main Bearing
Retrospekt is offline   Reply With Quote
Old 10-25-2009, 06:40 PM   #7 (permalink)
抵抗は無駄です
fenixus's Avatar
thanks guys. good to know it's common. yes i have alloy wheels. i picked up from Autozone a $4 rubber mallet (and higher 2 1/2t compact jack). i just hit the rear tires from back 2-3 times with the mallet and wheels broke free. took me 2 seconds per wheel
