Originally Posted by rty
If you are replacing your valve cover gaskets my advice is:
Don't bother replacing the spark plug gaskets unless they are in fact leaking. It is a pain in the ass to them them out and put new ones on. I wish I knew that before I started.
Man, I dunno. It would REALLY suck to do all that work on the V6's and then have them leak a short time later. When I did mine the old seals were brittle as hell; they crumbled at the least bit of persuasion. It isn't super hard to replace 'em once you figure out the trick; that there's a metal hoop embedded in the gasket that must be bent/destroyed to get it out.
