there are two bolts you need to turn to adjust the belt, loose the one on the side, then adjust the one on front for tightness, when the belt squeak, it mean it has been streched due to age or weather, and need to tighten it a little bit.
This is not a serpentine belt, but a steel pulley?
Rubbing a bar of soap on the belt quiets it down...for a few days.
Cleaning the pulley(s) groove with steel wool is a better option.
A smooth pulley surface increases belt contact area.
A rough pitted pulley tears at the belt edges, reducing life.
If plastic pulley, keep clean, use degreaser.
Reason: steel/plastic
belt dressing sort of softens the rubber of the belt to make it a little more sticky and remove glaze. it's a cheap way to try and get a few more weeks or months out of a dying belt.
generally when a multi-rib belt starts squealing, it's either time to replace the belt, or to find out which pulley is providing too much resistance (not turning smoothly) and replace it. which on our cars means alternator or a/c compressor. or p/s pump but that's rare for it to sieze.
__________________ 98 Camry CE v6 5s 97 MX-5 95 Camry SE v6 2dr SC (sold) www.gibson99.com
A V belt works by pulling itself deeper into the pulley groove as more load is applied. The friction grip is created by the pulley sheave walls applying pressure. The belt only has to have enough tension to start the pull-in process.
If a V belt is slipping, the problem isn't the belt tension unless the belt is sloppy loose. The problem is often something that keeps the belt from wedging into the groove, either rough pulley sides or when the pulley sides wear to a concave profile.
the same concept applies to a multi-rib (often called a micro-V) belt. same concept, just on several smaller V grooves, but this style also adds the ability to apply friction to low-load items (or idler pulleys) using the smooth side of the belt.
volkswagen uses double-sided milti-ribbed belts on many models - they look like a regular multi-rib belt, but with grooves on both sides.
and yes, all gen3 and up camrys use multi-rib belts. on cars made in the last 15 years or so, the traditional V-belt has gone the way of the dodo... nobody uses em anymore except on lawn equipment and stuff.
