Locked Out!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-25-2009, 10:59 PM   #1 (permalink)
.xShAgUaRx.'s Avatar
View .xShAgUaRx.'s Photo Gallery
Locked Out!!!
So i was resting my ecu and my hazards go off because the security system thing in my camry. I put the keys in the ignition shut the door and the doors then locked. know i have no key. Is there a way i can open my doors with out having to break a window or call a lock smith??
1993 Toyota Camry SE v6 5spd
1980 Pontiac Formula Firebird
2003 Chevrolet Silverado 1500 Z71
.xShAgUaRx. is offline   Reply With Quote
Old 10-25-2009, 11:27 PM   #2 (permalink)
View CJCride's Photo Gallery
Canada
If any window is even open a crack, you may be able to get a coat hanger in there. Pull open the door handle, move the window crank to open a little more or even hook the key ring and pull it to freedom.
If the trunk is open pop the 60/40 split open and slither in.
CJCride is offline   Reply With Quote
Old 10-26-2009, 12:44 AM   #3 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
you can also take the VIN to the dealership and get a key cut for about $5.
'07 Honda Ruckus Big Bore
Old 10-26-2009, 01:13 AM   #4 (permalink)
View felpz123's Photo Gallery
this..
felpz123 is offline   Reply With Quote
Old 10-26-2009, 03:33 AM   #5 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
good idea! my first thought was to go for a hanger
Old 10-26-2009, 12:44 PM   #6 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140495
i use a wood shim and a thin metal rod. gently pry the top of away from the frame, wedge in the shim and slide the medal rod down and press the unlock button. ive used this technique on several cars. but not in a bad way, officer...
Old 10-26-2009, 01:13 PM   #7 (permalink)
TOYODA KAMURI
the_professional's Avatar
View the_professional's Photo Gallery
really?
I didn't think you could force the locked door open enough to get the rod in.
My security system, locks my doors once in a while with my keys in the car, & once in the ACC position, cause although the car recognizes the key in the ignition at any position, the security auto lock only recognizes it if the key is in the ON position.
i love my 1992 Toyota Camry LE 2.2L 5S-FE - 73K
9005 NIGHT GUIDE LOW BEAMS|FOG LAMPS|PIONEER HU&AUDIO|KEYLESS ENTRY
1995 Acura Legend LS KA7 3.2L C32A - 87K
SADLY, SHE HAS MUCH MORE MODS...
the_professional is offline   Reply With Quote
Old 10-26-2009, 02:01 PM   #8 (permalink)
Newbie
deezeejoey's Avatar
View deezeejoey's Photo Gallery
I've done that on my old Olds. works well, kind of scratched it a but tho.
deezeejoey is offline   Reply With Quote
Old 10-26-2009, 02:36 PM   #9 (permalink)
View Kenny_McCormic's Photo Gallery
Use two nylon wedges to get the corner pried open, then insert a rod to work the lock, this really does work
Kenny_McCormic is offline   Reply With Quote
Old 10-26-2009, 02:54 PM   #10 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
Bring something to prove that u own that car with the vin #. they will not cut without a title or something
skewe is offline   Reply With Quote
Old 10-26-2009, 03:52 PM   #11 (permalink)
Freakin Scooters
Every dealer is different. Mine didn't ask for it, but you SHOULD have a title or something of that nature.
I wouldn't recommend forcing entry just because of the chance of minor damage. I'd rather hand over $5 and get another key.
Old 10-28-2009, 07:34 AM   #12 (permalink)
Canada
Originally Posted by felpz123 View Post
this..
I agree guys, but that does him nothing at midnight Sunday in Washington.
Old 10-28-2009, 09:54 AM   #13 (permalink)
Freakin Scooters
1993 Toyota Camry se v6 5spd
1986 Honda Accord lx-i
3 cars... I think he'd be okay for 24 hours or so.
Old 10-28-2009, 02:49 PM   #14 (permalink)
Canada
You win.
Just wanted to get him in ASAP.
Old 10-28-2009, 04:15 PM   #15 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
my local dealer cuts keys at no charge if you bring your own blank key. all they need is proof of ownership (e.g. registration or title) and your driver's license. it takes 5 mins. if you don't have a blank (i got mine off ebay) i think they charge something like $40 if transponder programming is involved.
