Whenever you replace the water pump, replace the timing belt (and other drive belts as well). If you have more than 60K miles I'll do the pulleys as well (some wait until > 120K miles). So YMMV.
I like to use Gates belts and hoses, but you may prefer OEM (Dayco-, Brando-branded Toyota belts). Look at a Gates Timing Component Kit. It'll have the belt, pulleys and a brief instruction sheet. rockauto.com.
I'd remove the pulleys, crank sprocket, sensors, so coolant doesn't soak them. Might want to check Autozone's free repair guide, with registration.
Originally Posted by thaharlequin
Allrighty, I was having trouble w/ coolant overflow and leaks, and I guess the pump finally gave up the ghost, because I can fill from the top and watch it dribble out from what I'm guessing is the weep hole on the bottom. My haynes repair manual is fuzzy on what I have to actually pull off to access the wp. To replace it, can I just remove the timing belt, mark everything so I can reuse it, leave all the pulleys/tensioners and such on, then replace the wp, or do I have to remove more than just the belt?
