2001 camry headlight relay - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-27-2009, 09:51 AM   #1 (permalink)
View dvp59's Photo Gallery
4th Generation 2001 camry headlight relay
Hi, I need to know what controls the headlights on 2001 camry. If you should leave the lights on,in this car, it will kill the battery. It did work, when you turned off the key and opened the door, the lights went out.I have tryed to find it under the hood and also using an ohm meter on all the one's I found. Thx. D.
dvp59 is offline   Reply With Quote
Old 10-27-2009, 10:28 AM   #2 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3626750
D,
Let me move this thread over to the Gen 3 & 4 Camry forum so the people there can help you find an answer, but I'd also recommend to you to search that forum too for a solution since it may have been covered in a past thread. Best of luck....
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is offline   Reply With Quote
