Horrible, horrible noise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-28-2009, 06:33 PM   #1 (permalink)
View cash4clunker's Photo Gallery
3rd Generation Horrible, horrible noise
First, let me say Hi and thanks already for the info I've found here to get my no-start problem fixed. (Bad coil in distributor.)
I was in the position a few months ago of needing a cheap, cheap car and ended up with this '92 Camry 4 cyl. The good thing is this car seems great for DIY'ers and I'm going to learn to be one.
My problem was this morning I went to start the car and it made this horrible metal-on-metal grating noise. I of course immediately released the key. As I urgently needed to be somewhere, I hesitatingly tried cranking it again and everything worked as it should. While driving to my destination, I got on the phone to triple-A and ordered up a membership - just in case :-)
So would this likely be the starter? Maybe some gear teeth ended up in a position that made it hard to turn at first? Is this something that happens on a rare occasion or is it a harbinger of trouble to come?
Many thanks in advance.
p.s. - I have lots of things to fix: shocks, flakey speedometer (sensor on transmission), power windows, door sensors, lights, and probably a dozen other things as well. I've already found lots of good info here and in my Haynes book but I'm sure you'll be hearing from me plenty often too.
cash4clunker is offline   Reply With Quote
Old 10-28-2009, 06:46 PM   #2 (permalink)
TOYODA KAMURI
the_professional's Avatar
View the_professional's Photo Gallery
Yep, you got it, its your starter.
Mine made an odd sound once a year. I had it tested, and its fine. Just make sure you get adequate volts from your battery, sometimes it'll make a funky sound if your not getting enough voltage.
i love my 1992 Toyota Camry LE 2.2L 5S-FE - 73K
9005 NIGHT GUIDE LOW BEAMS|FOG LAMPS|PIONEER HU&AUDIO|KEYLESS ENTRY
1995 Acura Legend LS KA7 3.2L C32A - 87K
SADLY, SHE HAS MUCH MORE MODS...
the_professional is offline   Reply With Quote
Old 10-29-2009, 12:42 AM   #3 (permalink)
RU2CHKN?
RU2CHKN's Avatar
Gameroom cash: $191865
View RU2CHKN's Photo Gallery
same thing happened to me as well and yeah check to see if you have adequate voltage coming from the battery
RU2CHKN is offline   Reply With Quote
Old 10-29-2009, 12:53 AM   #4 (permalink)
whip_cracker's Avatar
View whip_cracker's Photo Gallery
Yeah... have heard one of those noises before. Sounds like starter. If it keeps happening, I'd be getting that fixed. If your battery's a heap-a, turd that and get a new one. Remember: Just coz it reads 12v, doesn't mean it's packing any power. It's the amperage that you're needing. Mind you, you might already know this for all I know.
whip_cracker is offline   Reply With Quote
Old 10-29-2009, 05:42 PM   #5 (permalink)
View Kenny_McCormic's Photo Gallery
Have the battery load tested. If batt is good pull the starter and make sure the gear slides properly, lube if its binding or whatever.
Kenny_McCormic is offline   Reply With Quote
