Also take a look at the rear sway bar bushings, start there. They will make noises as you drive over small bumps. The bar will move up/down making the noise. You can check on the ground if you don't have ramps. Just grasp the swap bar and move it up/down while looking at the bushings. If the bushings are worn, you will see space between the bar and the bushings. I have a noise when I go over a small bump and traced it down to the sway bar bushings, so far. I went to the dealer and bought the bushings and bolts, and will change them when I have a chance.
