IIRC it's metric but 3/8" should be closer. Anyone?
Make sure the filter is pointed in the right direction or you'll block off the flow!
I verify three times. First by comparing the temperature differences of the cooler pipes. The cooler one is the return. Second, as if that's not enough, I add a segment of 3/8" clear PVC tubing (~10 cents/foot), and check the actual flow. Finally, with the filter installed and the PVC still in place, I check the flow again. It's much cheaper than a transmission.
Originally Posted by darkwingbenny
Vehicle is a Gen4, 1999 I4 Camry. I want to add a magnefine filter to the transmission. Does anyone know what size fits the OEM AFT cooler line hoses, 3/8 or 5/16?
TIA
Ben
