Problem with aftermarket grille.
I finally "glued" together the grille emblem that fell apart when I removed it from my original grille.
...went to put it in my new grille, and how 'bout it - doesn't go in. It seems like the bottom inside part of the hole on aftermarket grille is slightly different from the oem version. Not sure how to explain it, but there's this little "slide"... and the bottom of emblem has a little triangle piece that's supposed to go over it, and lock in on the other side. I think the "slide" is designed a bit differenty on the aftermarket, and it won't fit through. I pushed so hard that the emblem fell back apart.
I wish these fuckers would make aftermarket emblems to fit!
2000 Toyota Camry LE (Japan made) i4 5S-FE 367,000+ miles.
