how to add keyless entry on 2002 camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-01-2009, 01:42 AM   #1 (permalink)
View gg22's Photo Gallery
my 2002 camry do not have remote control when i brought from the owner, can i add one, how much, thanks
gg22 is offline   Reply With Quote
Old 11-01-2009, 11:13 AM   #2 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
did it have keyless from factory?
you can add alarm/keyless to your car.
local auto stores / stereo shops would have them.
would be cheaper to buy off internet
quick google search:
http://www.google.com/products?q=+ke...kit&hl=en&aq=f
Old 11-01-2009, 11:56 AM   #3 (permalink)
the last owner did not tell me whether the car has it or not, what is happened if it did not have it?
Old 11-07-2009, 11:12 PM   #4 (permalink)
still confusion
Old 11-08-2009, 12:58 AM   #5 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3626750
Originally Posted by gg22 View Post
still confusion
Yes, you can add an aftermarket kit for keyless entry. Just click on the link provided above by abew330 and you'll see a number of products available. Google search for additional aftermarket products.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is offline   Reply With Quote
Old 11-08-2009, 11:32 AM   #6 (permalink)
12V CONSTANT WIRE WHITE/RED Ignition harness
12V IGNITION WIRE BLACK/RED Ignition harness
SECOND IGNITION WIRE BLACK/YELLOW Ignition harness
ACCESSORY WIRE BLUE Ignition harness
STARTER WIRE BLACK/WHITE Ignition harness
PARKING LIGHTS (+) GREEN Harness At Bottom Of Fuse Box
POWER DOOR LOCK (-) BLUE/YELLOW Harness In Driver’s Kick Panel
POWER DOOR UNLOCK (-) BLUE Harness In Driver’s Kick Panel
Test power door lock wires by using the key in the passenger door.
DRIVER DOOR TRIGGER (-) RED/GREEN Plug Lower Left Of Fuse Box
PASSENGER DOOR TRIGGER (-) RED/GREEN Plug Upper Left Of Fuse Box
REAR DOORS TRIGGER (-) RED/WHITE Plug Bottom Of Fuse Box
TRUNK TRIGGER (-) GREEN Harness In Driver’s Kick Panel Or At Light In Trunk
TRUNK RELEASE (5-wire) WHITE/BLUE Harness In Driver’s Kick Panel
TACHOMETER WIRE BLACK At Ignition Coil
BRAKE WIRE (+) GREEN/WHITE Harness At Bottom Of Fuse Box
HORN TRIGGER (-) GREEN/BLACK Harness At Steering Column
LEFT FRONT WINDOW UP GREEN At Driver Window Motor Inside Door
LEFT FRONT WINDOW DOWN RED At Driver Window Motor Inside Door
RIGHT FRONT WINDOW UP GREEN/WHITE Harness In Driver’s Kick From Driver Door
RIGHT FRONT WINDOW DOWN RED/BLUE Harness In Driver’s Kick From Driver Door
LEFT REAR WINDOW UP GREEN/YELLOW Harness In Driver’s Kick From Driver Door
LEFT REAR WINDOW DOWN RED/YELLOW Harness In Driver’s Kick From Driver Door
RIGHT REAR WINDOW UP GREE/BLACK Harness In Driver’s Kick From Driver Door
RIGHT REAR WINDOW DOWN RED/BLACK Harness In Driver’s Kick From Driver Door
