here is a tip if you trying to remove it at home without power tools
don't jack up the car,
dont' loose any lugnut, caliper/brake.
remove cotter pin,
use at least 1/2" drive braker bar or ratchet, 6 point 30mm socket, 3/8 wil break before the nut loose.
use a long 6 to 8 ft extension pipe $6 to $10, from fence department from lowes or home depot.
have someone sit in driver seat, step on brake padel hard, and make sure the socket is all the way in the nut, it should come loose.
i did it with 2 or 3 ft extension pipe, believe me, wasted my time and energy, won't loose until i use longer pipe for leverage.
