Valve cover torque? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-01-2009, 07:29 PM   #1 (permalink)
View RadioFlyer90's Photo Gallery
4th Generation Valve cover torque?
My wife's car just developed it's very first oil leak at just under 130,000 miles. It appears to be coming from the corner of the valve cover, so I plan on replacing the gasket.
I replaced a similar gasket on a different brand car and ended up warping the valve cover, causing a bigger leak. I didn't think I had overtightened anything, and felt as though I had tightened it evenly (though I didn't use a torque wrench). Is this a concern on my wife's car? If so, does anyone know the proper torque?
By the way, this is a '98 LE, 4-cylinder.
Thanks!
1990 Toyota Pickup, 2wd, 4-spd, reg. cab (sold!)
1998 Toyota Camry, 4cyl auto
1971 Toyota Hilux, 4cyl, 4spd, 4wd, 4 tires...
RadioFlyer90 is offline   Reply With Quote
Old 11-01-2009, 07:29 PM   #2 (permalink)
Creeps228's Avatar
Gameroom cash: $286818
iTrader Score: 6 reviews
View Creeps228's Photo Gallery
33 ft pounds
99 5s w/ V6 '01 Solara Brake Conversion & 1985 AW11 MR2 5spd
Camry: Tokico Blue's w/ Ebiach Lowering Springs on Motegi FF7 17" Rims with FALKEN ALL SEASON SPORT TIRES
MR2: 7A-GE
FS: Gen 4.5 Clear lense/JVC HU&Radar
Creeps228 is online now   Reply With Quote
Old 11-01-2009, 11:12 PM   #3 (permalink)
Gameroom cash: $303255
Originally Posted by Creeps228 View Post
33 ft pounds
That's way to high. You will probably crack the valve cover at that torque. Tighten the 30MM nuts to 17 ft lbs in 3 even passes. First 6 ft lbs, then 12 ft lbs, and finally 17 ft lbs.
Mike
Old 11-02-2009, 03:43 AM   #4 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
Mike
no you snap the bolts before then, i did that
^ and leaving it that way!
Old 11-30-2009, 10:55 PM   #5 (permalink)
View jasguild's Photo Gallery
Mike
Unless I am misreading it, the online manual on page 58 of the file named "Engine Mechanical I-4" says it should be 33lbs of torque
8. INSTALL CYLINDER HEAD COVER
(a) Remove any old packing (FIPG) material.
(b) Apply seal packing to the cylinder head as shown in the
illustration.
Seal packing: Part No. 08826–00080 or equivalent
(c) Install the gasket to the head cover.
(d) Install the head cover with the 4 grommets and nuts. Uniformly
tighten the nuts in several passes.
Torque: 44 N·m (450 kgf·cm, 33 ft·lbf)
HINT:
Install the grommets so that their markings are as shown in the
illustration.
jasguild is offline   Reply With Quote
