Use a mirror to check the rear of the engine near the firewall. Most likely oil is leaking out from there. Also check the cover nuts, they may be loose because spark plug tube seals took a set.
That generation's valve cover design isn't good at all. Toyota revised it in 02.
Originally Posted by gina22
i have a 1996 camry LE that i recently bought. i took it to a mechanic before the purchase and the only think wrong with it was a leak in the valve cover gasket.
the car drove perfect before replacing the valve cover gasket, now it smokes in the engine and has lost its power when driving (it is slow).
could this be another leak? and why would replacing the valve cover gasket make it worse? Not seeing much oil on the ground - specks. it started smoking the day after the valve cover replacement.
anyone have an idea of what the issue is? i checked the oil and the level and color are fine. the car didn't have any antifreeze so filled that up, but still smoking and worse.
