Originally Posted by samgvr4
thanks you my friend, i assume i will have to replace it.
Most likely. It's worth inspecting first, 'tho -- might be a bad wire/connector or vacuum hose.
http://www.camrystuff.com/manuals/Ge...on_Control.pdf , page 19 shows roughly the location (back near the EGR valve). Page 28 is the start of the inspection and R&R instructions...looks to be a pretty easy DIY project.
If you need to get the part, you can look up the actual part number at
http://toyodiy.com/parts .
