Here are my notes from when I replaced the fender.
The door hinge bolts are trivial to reach once the fender is off, but the door is difficult to align correctly with the fender missing.
Gen 3 Camry fender fastener list
All are 10mm head, #2 or #3 phillips (fender liner)
The nuts at the bumper requires a deep socket or 10mm box wrench
At the door edge you need a nutdriver or socket extension
http://www.toyodiy.com/parts/p_U_199...PNKA_5302.html
Start by removing the grill, corner light, and headlight
Grill: 2 obvious screws
Corner light: 1 screw at top, pulls forward
Headlight: 2 bolts, 1 nut (one under grill, two behind corner light)
Next remove the fender liner
3 screws (#2, captive washer) around lip
2 screws (#3 large) at mudflap
8 screws (10mm+#2 head, captive washer)
Remove the intake resonator -- the platic tank blocking access from the
wheel well to the corner light area. Yes, you definitely need to.
2 long screws (10mm head)
Remove the bumper, or at least bend one side forward to release fender
Two nuts at the bumper/fender joint, reached from the wheel well
Use a deep socket, or work slowly with a box wrench
One screw about six inches back, reached from inside wheel well
Engine screening
Quarter-turn fasteners
Top edge
Two or three along hood line 90119-06288
One hidden under the cowl louver (trim under wiper arm)
You only need to remove the forward of the two screws
Door edge
One at the top reached from the open door
One reached from the fender liner
Two pointing up from the rocker panel 90119-06353
Clamping in a spacer 53878C
Forward edge
Two nuts at the corner light
Wheel arch and bottom
Two holding a mudflap-area reinforcement 90164-60024
Reinforcement 52827B/828B
Four at wheel arch edge, for liner 90159-50296
Into speed nut on liner 53879A
Liner is held by five screws 90159-80403 into nylon body nuts 90189-06006
