Oil Pan Removal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-04-2009, 02:53 PM   #1 (permalink)
Gameroom cash: $167485
iTrader Score: 6 reviews
View haux's Photo Gallery
Exclamation Oil Pan Removal
I'm working on my car right now replacing the valve cover gasket, pcv and vent hose. I figured I would replace the oil pan gasket too since it appears to be leaking. How the heck do you take down the oil pan? One side of it is blocked by something. And that side also had some weird foam on it. Is there a DIY out there?
Three hours of effing sunlight left!
2000 Toyota Camry LE (Japan made) i4 5S-FE 367,000+ miles.
haux is online now   Reply With Quote
Old 11-04-2009, 03:35 PM   #2 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
working on gen4 I4?
Old 11-04-2009, 08:25 PM   #3 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
4cyl is a bitch because the exhaust is on the way as well,
i managed to remove and reinstall without removing the exhaust flex pipe using swival 1/4" and a couple different length extensions, and try all kinda position to slide it out.
the foam is there between the tranny and oil pan, don't know why it exist.
but behind the foam, where are two more 10mm bolts.
http://mysite.verizon.net/vaio338168/avator.jpg
2002 2AZ-FE, LE Phantom Grey Pearl, Retrofitted with LS430 Projectors on SE Headlights. Aftermarket Foglight
bronzemaxell is offline   Reply With Quote
Old 11-05-2009, 09:53 AM   #4 (permalink)
quangtran89's Avatar
iTrader Score: 8 reviews
View quangtran89's Photo Gallery
On my car I had to push back the transmission a bit to have access to the bolt.
quangtran89 is offline   Reply With Quote
Old 11-05-2009, 06:48 PM   #5 (permalink)
View Oldcar95's Photo Gallery
On my 1995 4 cyl, I could take the oil pan down without removing the exhaust pipes. Not sure on Gen 4s. Once you get the oil pan down and cleaned, pratice putting it back up. You will have to angle it to clear parts. Remember how you do it. Because you will need to make the oil pan gasket out of RTV. By practicing putting the pan back up, you won't make a mess with the RTV.
Oldcar95 is offline   Reply With Quote
Old 11-05-2009, 08:14 PM   #6 (permalink)
I bought an aftermarket Fel Pro gasket. It's made of some cork material. However, I will also use RTV to hold the gasket down.
Old 06-09-2010, 03:31 PM   #7 (permalink)
View Camry LE 94's Photo Gallery
where did you get this gasket? i need one for my 96 L4. thanks.
1996 Toyota Camry DX [230K]
DEPO Chrome HL's w/ converted Nokya Arctic White 9005 low beams, CF Dash Kit, 14" AR Rims
Advanced Camry DIY'er Noob
Camry LE 94 is offline   Reply With Quote
Old 06-09-2010, 03:49 PM   #8 (permalink)
Either Advance Auto Parts or AutoZone. Make sure it's Fel Pro!
Old 06-09-2010, 06:34 PM   #9 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
it's an i4 or I4 as inline4 not L4 as some dumb online stores describe
Old 06-09-2010, 09:24 PM   #10 (permalink)
I heard it can be called either or; "In a specification chart or when an abbreviation is used, an inline-four engine is listed either as I4 or L4 (for longitudinal, to avoid confusion between the digit 1 and the letter I)."
Old 06-09-2010, 09:36 PM   #11 (permalink)
抵抗は無駄です
fenixus's Avatar
never heard of it. longitudinal sounds like more related to geography than mechanics, besides one of its meanings is a synonym to vertical
when i first time wrote a post on this forum describing i4 engine as L4 because i confused lowercase L/l with uppercase I then someone yelled at me
but i won't argue as i don't care hehe
