Originally Posted by mikesb
I have a 1999 camry v6 that has a small coolaant leak under the intake manifold.I thought it might be the bypass hose so i pulled the manifold this morning. The hose was ok but looks like the knock sensor is leaking where the metal shell is crimped over the plastic. Do knock sensors do this when they go bad? Car ran fine and there the service engine light is not on.
Unless there is a serious block problem, the knock sensor doesn't contact coolant or oil -- it's just screwed into the metal of the block.
Most likely, the "leak" is coming from somewhere else, and the knock sensor is just getting leaked upon.
