Fuel Filter '00 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-07-2009, 05:56 PM   #1 (permalink)
View iamcarnoob's Photo Gallery
I've got a V6 Camry and am trying to do my first car repair of any sort. I got a check engine error code that makes the fuel filter seem likely since my only signs are worse gas mileage (and I did both o2 sensors last year). Anyway, I don't see how I'm supposed to remove the top part. There's no clearly visible bolt. What should I be looking to remove on the top part?
The bottom part I guess I need to find a friend with a flare wrench to borrow if I can find one. I can't unscrew the bolt otherwise. It's pretty darn tight. Is that normal?
iamcarnoob is offline   Reply With Quote
Old 11-07-2009, 06:10 PM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
yup normal, that flare nut whole reason why i have a set of box end wrenches.
top is just a banjo bolt, 14mm i believe.
10mm ring clamp around the middle.
^ and leaving it that way!
Old 11-07-2009, 06:12 PM   #3 (permalink)
twinjetguy's Avatar
View twinjetguy's Photo Gallery
Now I'm not a pro, but I really doubt that a bad fuel filter would throw a check engine light. I could be wrong. Did your code reader only give the number? I purchased a code reader that gives you the number and what it means.
The guy you want to ask about swapping out your fuel filter is trd4life. He knows exactly what you need to do/use to do this.
2001 Camry with too many parts to list!!!
twinjetguy is offline   Reply With Quote
Old 11-07-2009, 06:15 PM   #4 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
What OBD-II code are you getting?
Flare nut wrenches: $9.99 set of 5
http://www.harborfreight.com/cpi/cta...emnumber=99993
Is the top quick-connect style fitting? You may need a new click-on plastic clip if the old one breaks.
Relieve fuel pressure first and disconnect battery after that.
Old 11-07-2009, 08:16 PM   #5 (permalink)
Error code is P0174 Air/Fuel mixture systeam lean bank 2.
Which wrench do I use for the banjo bolt?
What do you mean by style fitting? The quick connect on top is tight on there at the moment but I haven't loosened anything.
Old 11-08-2009, 10:31 AM   #6 (permalink)
For what it's worth, the probable causes are listed as:
Low fuel pressure
Faulty MAF/VAF sensor
Cylinder misfired condition
Faulty HO2S/AF sensor
Large vacuum leak
Old 11-08-2009, 12:38 PM   #7 (permalink)
Besides what Iamcarnoob mentioned, sure, a plugged fuel filter can do it too. IMO, these wimpy fuel filters are best replaced 15-20K miles.
I was referring to your comment about "I don't see how I'm supposed to remove the top part. There's no clearly visible bolt." So I said it's a quick connect type connection. No bolts needed.
Are you talking about the banjo on the fuel rail? Not sure you need to touch that.
Old 11-08-2009, 01:42 PM   #8 (permalink)
View chasman's Photo Gallery
4th Generation Fuel filter quality?
Hi John,
Please tell me more.
Is there a higher quality alternative to them?
Chasman
202k one-owner
87 I4 Camry Wgn
ES250 Strut Brace, Tokico Blue, Ceramic pads
Falken ZE-512, Goodyear Eagle UltraGrip H-rated M&S
chasman is offline   Reply With Quote
Old 11-08-2009, 11:40 PM   #9 (permalink)
I don't think anybody ever did a fuel filter comparison like many have done with engine oil filters. So can't say about various filters' quality.
I guess you can use any name brand fuel filter, such as Toyota's Denso, Fram, Wix, etc. Whatever makes you sleep at night. The small size means more frequent replacements to reduce loads on the fuel pump. It also depends on how clean your local gas station is.
I use the latter two brands on many different cars. However, with the newer in-tank filters I'd use only OEM. These large ones should be good > 100K miles however.
Originally Posted by chasman View Post
Hi John,
Old 11-09-2009, 03:04 PM   #10 (permalink)
Are these same small fuel filters used on all years of the Gen4 Camry?
A parts salesperson advised:
I would not change the fuel filter. Unless the car has been sitting for years and not been driven. You run the risk of bending the lines that go to the filter and causing yourself more grief
How much of a concern is this for do-it-yourself owners and for the pros?
Thanks
Chasman
202k one-owner
87 I4 Camry Wgn
Old 11-09-2009, 08:58 PM   #11 (permalink)
I believe the in-tank only came with Gen 5 and later.
Sure, if you live where corrosion is a problem then you need to be careful. The flare connection isn't the smartest for these regions. Or a twisted fuel pipe will result!
So my guess is, like spark plugs, these things shouldn't be left on there forever.
Thanks
Old 11-10-2009, 01:42 AM   #12 (permalink)
96 3MZ M/T
chronoti's Avatar
i had a filter throw a lean code got some dirty gas in pembrook pines (near miami) changed the filter hasn't come back since.
the top of the filter is a banjo bolt that i normally take out with just a socket wrench with an extension. i have a fram in mine right now had it for about 7 years no problems so far.
Old 11-10-2009, 03:46 AM   #13 (permalink)
So all Gen4 (1997-2001) use "these wimpy (small size) fuel filters"?
Thanks for the additional info.
"Sure, if you live where corrosion is a problem ...
Such as any region where salt is used on the roads in winter?
Chasman
202k one-owner
87 I4 Camry Wgn
Old 11-10-2009, 11:11 PM   #14 (permalink)
The I4 has a banjo top bolt. The later V6 has a click-on quick connect style. I rather also see a banjo for the lower one but they put a silly flare connect on there.
Fram will probably give you more filtration area than a Wix. But the Fram media is paper thin and kinda folded/rolled into a toilet paper roll on a plastic cob. The Wix is more like an oil filter plated element. Different designs, but probably don't matter.
Old 11-11-2009, 05:52 AM   #15 (permalink)
View motorking's Photo Gallery
fuel filters
Good morning,
I am the technical manager for FRAM. I am happy to answer any questions you may have about fuel filters. Most OE filters that are not in tank do not see restriction untill around 75k miles. BUT-If you live in a area were they use salt on the roads in the winter, you should change it more frequently only to be able to keep the threads clean and coated with antisieze. You can get the tube nut frozen on the line and then twist the line when removing it. Questions answered on this forum or directly at Jay.Buckley@Honeywell.com
motorking is offline   Reply With Quote
