Repetitive clacking sound when engine is around 2000 rpm - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-07-2009, 08:13 PM   #1 (permalink)
View camry_98_owner's Photo Gallery
When ever I push the accelerator pedal down, when the engine is around 2000 rpm, something from under the hood makes a repetitive sound - as if a belt is hitting something. At higher rpms it dies down but there is still some sound although not as bad. i have posted the sound clip on youtube so that somebody here can listen to it and give me some ideas as to what could be wrong.
Thanks in advance.
camry_98_owner is offline   Reply With Quote
Old 11-08-2009, 01:10 AM   #2 (permalink)
View camrycraig's Photo Gallery
hows the power?
camrycraig is offline   Reply With Quote
Old 11-08-2009, 01:30 AM   #3 (permalink)
I do not think there is any loss of power. It seems to be doing ok. I drove 50 miles in it today, and it was ok. But I am worried that this noise (which seems to be getting worse) may be damaging something.
Thanks.
Old 11-08-2009, 08:04 AM   #4 (permalink)
I think you need to do some investigation. Like draining the oil and looking for metal pieces. If none consider pulling the oil pan and checking the bearing caps, removing the valve cover and checking the valve train. Its hard to tell from the clip bc of the ambient noise but that sounds like mechanical failure to me. Good luck.
Old 11-08-2009, 01:00 PM   #5 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Is this coming from under the timing cover?? How long ago was the timing belt changed?
The I4 doesn't have an automatic tensioner, and the timing belt will stretch with time (~50K miles). So that's one of the possible areas to look into.
You can try the mechanic stethoscope, a very long screwdriver, or a garden hose. Be careful of moving engine parts.
http://www.harborfreight.com/cpi/cta...emnumber=41966
http://www.youtube.com/watch?v=P4i1s09VU3E
Thanks in advance.
Old 11-08-2009, 01:03 PM   #6 (permalink)
It also sounds like you don't have to rev it. It's there at idle speed?
Old 11-08-2009, 01:13 PM   #7 (permalink)
cruisn76's Avatar
View cruisn76's Photo Gallery
Check your dog bone mount to see if it worn to scraps. Check all the mounts while your at it
could be alot of movement from the engine. Just a possibility
92 Camry 4 cyl 5 Spd
390,000km, Retrofited Projectors + 6000k HID, 2500k Fogs, SRI, K-Sport Coilovers, TRD Rear Sway Bar, GEN4 Ralco Short Shifter, Alpine 7" IVA-D900, 2 x 10" MTX / MTX 900W Amp
cruisn76 is offline   Reply With Quote
Old 11-08-2009, 01:39 PM   #8 (permalink)
Momentum Car Crew Camry
View H.Rivera's Photo Gallery
it sounds internal.. i want to say piston internal but most likely that motor either has to get opend and fixed or just replaced.
just from my expirience.
H.Rivera is offline   Reply With Quote
Old 11-08-2009, 02:34 PM   #9 (permalink)
asphalt victory's Avatar
View asphalt victory's Photo Gallery
if that is a 5sfe you have bad rod bearings and you wont get more than 100 miles out of it without catastrophic engine failure by that i mean a piston flying through the oil pan i have blown 2 5sfe's with that same noise
does the oil pressure light come on?
does it make this noise with a load on the engine?
your temp fix would be replacement rod bearings and studs
better off either getting a replacement engine and hoping for the best
MAY AN EMPTY PARTS BOX BE MY WINNING TROPHY
asphalt victory is offline   Reply With Quote
Old 11-08-2009, 02:38 PM   #10 (permalink)
yea just listened to that clip again that is metal on metal
dont drive
Old 11-08-2009, 03:15 PM   #11 (permalink)
View Kenny_McCormic's Photo Gallery
You lost a bearing.
Kenny_McCormic is offline   Reply With Quote
Old 11-08-2009, 03:48 PM   #12 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
Yeah definitely stop driving it, your just killing any hopes of the engine being salvageable.
Sounds like a piston wants to see the outside world.
Ive heard a water pump make a similar clatter but it was much much quieter.
carsrus is offline   Reply With Quote
Old 11-08-2009, 06:43 PM   #13 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140495
that certainly sounds like a lower end bearing to me. depending on how bad everything is worn, it might be able to be salvageable, but less likely the more you drive it. plus there is the whole throwing a rod through the block thing too that will most likely happen eventually.
ghettosled is online now   Reply With Quote
Old 11-09-2009, 08:44 PM   #14 (permalink)
Good prognosis by everybody. It was indeed the 3rd engine lower bearing. And to add to the problems the damage to the engine is beyond repair. The cost estimate to rework is about $7000. So I have at this point decided to park the car in the drive way and not worry about fixing it.
Old 11-09-2009, 11:32 PM   #15 (permalink)
Canyon Killer
View ekopel's Photo Gallery
dude, ebay. used low mile 5s's are cheap. well worth it.
LOTS OF GOOD 1MZ PERFORMANCE/STOCK STUFF FOR SALE! HERE!
ekopel is offline   Reply With Quote
