2000 camry window regulator - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-08-2009, 08:46 AM   #1 (permalink)
View silk04's Photo Gallery
Hello I'm new here. A month ago my window stopped rolling up. I opened the panel and seen that the regulator parts had broken. i been taping the window up so far. I want to know is there a place on the forum that can tell me how to install one? Also what type of cleaner can take the tape residue off the window? Your comments are appreciated.
silk04 is offline   Reply With Quote
Old 11-08-2009, 09:16 AM   #2 (permalink)
View White95Cam's Photo Gallery
Read Me: Camry FAQ ------> READ FIRST -----> Comprehensive List of Gen 3/4 INFO and DIY
read above lots of information
W95c
White95Cam is offline   Reply With Quote
Old 11-08-2009, 09:25 AM   #3 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
Cleaner? I think you need some marine or white grease
skewe is offline   Reply With Quote
Old 11-08-2009, 12:32 PM   #4 (permalink)
I am sorry, I missed that part. Get some adhesive remover. An autoparts store or a home improvement place will have it.
W95c
Old 11-08-2009, 01:11 PM   #5 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Do you have a bad motor or the regulator assembly? Often the motor goes bad:
http://info.rockauto.com/Cardone/Det.../821103-01.jpg
You can usually borrow the rear window motor on the same side. Use it in place the bad one, if not just to crank up the window, especially if there are weather and security issues. And when you get the new one put it in the back.
This DIY is for the older cable style. Yours should be a crank style. Check Autozone's free repair guide, with registration.
DIY Replace Window Regulator - Camry 92-96 & Equivalent Models
Crank style regulator w/ motor:
http://www.rockauto.com/catalog/moreinfo.php?pk=1534334
Old 12-05-2009, 12:01 PM   #6 (permalink)
Finally got my regulator.SadlyIi have a crank style. Is there some lube that I need to buy for the parts?
Old 03-26-2012, 01:12 PM   #7 (permalink)
View Zain's Photo Gallery
dont want to start another topic. so let me explain my problem
my front left side window will come down but then it take hours to go back up.
i am pretty sure the motor is weak.
i was looking at parts online and theres a complete assembly?
do i need just the motor or the complete assembly?
Zain is offline   Reply With Quote
Old 03-26-2012, 06:13 PM   #8 (permalink)
View 1996camry's Photo Gallery
I have the same car 2000 toyota camry with the same problem front driver side window goes down but slowly goes up...
suspect the motor goes bad, so I just bought the MOTOR ONLY at rockauto.com... you still beable reuse the track of window regulator...just remember when you remove the old motor, count how many teeth on the track so you can put back to the right spot.
my motor arrive next week, so i'll replace and let you know.
1996camry is offline   Reply With Quote
Old 03-29-2012, 05:13 PM   #9 (permalink)
thanks man
let me know how it went, and how much did you pay for the motor only?
Old 04-03-2012, 07:48 PM   #10 (permalink)
View lilredvettefan's Photo Gallery
I have the same problem but I have replaced the motor and regulator twice. I have an alignment issue and can't figure out how to adjust it so the window comes back up smoothly. Once the window goes up about 90% of the way it starts to lean towards the engine, versus staying in the track and it gets stuck. I then have to push it back towards the weather strip and then roll it up again. Any idea of how to fix it?
lilredvettefan is offline   Reply With Quote
Old 04-23-2012, 01:33 PM   #11 (permalink)
rock auto has 3 different brand for window motors
dorman
acdelco and another one
is anyone better then the other?
Old 04-23-2012, 02:32 PM   #12 (permalink)
View 69GTSport's Photo Gallery
If your window still works but is slow try spraying the window channels and seals down with Armor All. I was able to completely avoid having to replace a motor for over 7 years by trying this first and reapplying every spring and fall.
1999 Toyota Camry XLE V6.
1995 Toyota Camry LE 4dr. 2.2L.
2009 Harley Davidson Dyna Superglide Custom, customized to suit my tastes .
69GTSport is offline   Reply With Quote
