Look on either a door or pillar for a sticker. You should see the transmission code on there.
The sticker should have something like Manufactured by Toyota, blah, blah. And then it's either A140 or A540.
Actually if you have them the year and displacement there is one automatic choice for each engine. For automatics should be either the Aisin A140 series or Aisin A540 series.
Fram ATF kit is about $15. New strainer and cork-rubber gasket.
Originally Posted by asphalt victory
how do i find out if it was built in the US?
i can see a number plate
thing is its getting cold up here and the trans is acting up i want to change the fluid and filter A before theyrs snow on the ground
B befor the trans gets too bad
thanks
