idle issues getting ridiculous
o.k.,,looked at all the idle threads, done the tests,, for a refresher, this car 2.2liter, runs perfect, forever, if you drive around town, put it on the highway for constant distance driving, the car develops,well more like turns on a switch for a miss, then without load on the engine it stumbles and stalls, under load it goes down the highway, my last item was the coolant temp switch for maybe a weird signal to the ecm to richen mixture,,, and a third deep creep soaking of the iac,, it also tests out properly via the Haynes manual, drove car, at 18 miles it clicked and started its shenanigans, this time I drove to a Toyata dealer,,between the time at the service writer and then going to the lot to drive the car up, it went away again,,I stressed the car will present no drivability issues unless the tech goes quite far, they took the car in,,an hour or so later, they call me back to tell me an idle control motor,(iac), I said ,"well the car is idling and it checks good, how is it bad,,?", they called in the tech, he said everything checks right but the only thing that may control idle like that would be that module, but no garauntees, I then asked him about the mileage issues and he was unaware of that, the service writer failed to explain the issue properly, now he was miffed, he kinda just shrugged and said I dont know,,"it's working fine now,,",,,they did not charge me for the visit which was nice,,,. I went home rechecked the iac, it tested properly, then I took it off for a visual, looked good, went back to the dealer for a gasket,, I found Jason, the tech and showed him for his opinion, and maybe to see if he knew how it worked, he had no clue, and said they typically dont service the item, just replace them,,,,aaauuaghhh,,typical dealer b.s.,,,
does anyone know the functioning aspect of the iac,,the "air assist tube", looks to me to be a vacuume signal to the fuel pressure regulator, but the tech said no,,??its got to do something it's plumbed to the throttle body cavity,,??, and the water bypass cavity has an adjustable looking choke spring type setup,, what does this do, it somehow limits the iac valve travel,,,any help out there would be appriciated,,
Oh, yeah, after reassembly I redrove the car,,at 11 miles it happened again, I called Toyota and seen if they wanted me driving it in while it was stumbling, if that would help diagnose,, they said their tech already diagnosed it and didn't want it back unless that part was on,, the part they checked out as ok, with a shoulder shrug,,,,;-(
