Where is the PCV Valve? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-09-2009, 06:50 PM   #1 (permalink)
Gameroom cash: $302547
View ricamryman's Photo Gallery
3rd Generation Where is the PCV Valve?
I have a 93 Camry V6. 3VZ-FE motor. Where is the PCV valve located?...
ricamryman is offline   Reply With Quote
Old 11-09-2009, 08:01 PM   #2 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
go here and type your VIN and search for "ventilation valve":
http://www.toyodiy.com/parts/q_U_199...MRY_VCV10.html
i picked one of those '93 camry 3vz-fe and it seems pcv is located here:
http://www.toyodiy.com/parts/p_U_199...PGKA_1201.html
not much i can see by looking at that diagram, but there is a ventilation hose, if you can find it, then you can find PCV valve on the other end
Old 11-09-2009, 11:36 PM   #3 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
Rear pass side of the valve cover (firewall side). It sticks up at the edge of the intake plenum.
5 Lug Corolla WHAT?
Old 11-10-2009, 11:58 AM   #4 (permalink)
View aoe_mp's Photo Gallery
i have a 94 camry. i just change mine like 5 weeks ago. cause there were leak from the grommet. normal pcv valve last for a long time. if you want to check your valve is still good or not, you can just take it out and shake it . if you hear that click click sound then you are fine.
i went out to struass and got pcv valve for $5, groment for $3, the hose for $2.
aoe_mp is offline   Reply With Quote
